1967 383 'Commando' vs 'Super Commando'
69 Cuda 440
Legandary Member
Legendary Member
Wilton, Connecticut
1967 Mopar 383 'H-Code'
Plymouth Barracuda - 383/280 HP 'Commando 383'
Plymouth Satellite and Belvedere - 383/325 HP 'Super Commando 383'
Also,
Dodge Dart GTS - 383/280 HP - '383 4-Barrel'
Dodge Charger and Coronet - 383/325 HP - '383 4-Barrel'
One in the same, except for Exhaust Manifolds and Exhaust Piping.
All engine specifications were the same,
* Piston Compression
* Cylinder Head and Valve Size
* Camshaft
* Valve Train
* Intake Manifold
* Carburetor
* Ignition
The only difference was in the exhaust system. Was that truly a 45 Horsepower variation.
Based on tests on the 1967 A-Body exhaust system, it was obvious that the restriction in both
exhaust manifolds, and bends in the small diameter exhaust piping limited flow, resulted in
a 'net loss' of approximately 15 Horsepower and 400 RPM's compared to the 383 in the B-Body.
Barracuda...........Satellite & Belvedere...Dart GTS & Coronet
th
Yes the original exhaust was restrictive, nothing a set of good headers and bigger (oh say 3") exhaust pipes can't fix :twisted:
Yes, definitely restrictive, but -45 HP less than the 383/325 HP
Big-Body 'Super Commando'.
No, Chrysler overrated the 383/325 HP 'H-Code' by a big amount.
Here is what the NHRA 're-factored' the 383 engines to back in the 1990's,
with the stock exhaust system.
A-Body
1967 - 383/280 HP...........255 HP
1968 - 383/300 HP...........280 HP
1969 - 383/330 HP...........294 HP
B-Body
1967 - 383/325 HP...........270 HP
1968 - 383/330 HP...........283 HP
1969 - 383/330 HP...........283 HP
Road Runner, Super Bee & Charger
1968 - 383/335 HP...........302 HP
1969 - 383/335 HP...........302 HP
Teak,
NHRA calculated the 1967 383/280 HP in an A-Body with 'stock exhaust' and de-jetted
Carter AFB (575 CFM) - to a correct 255 Horsepower at 4200 RPM's.
The same 383 in the B-Body, with the better flowing exhaust manifolds and
'intermediate' exhaust pipe system was calculated to come in at 270 HP at 4600 RPM's.
1967 383 B-Body, Right Side Exhaust Manifold #2532464
1967 383 A-Body, Right Side Exhaust Manifold #2863900
1967 383 B-Body, Left {Driver} Side Exhaust Manifold #2532626
1967 383 A-Body, Left {Driver} Side Exhaust Manifold #2899002
Teak,
Found the 'performance results'
March 1967
1967 Plymouth Barracuda 'Fastback' 383/280 HP 'Commando 383'
3.23 Gears, w/Automatic Transmission
#3202 lbs ~ 280 HP = 11.44 Wt/Hp
Performance = 15.40 @ 92 MPH
1967 Plymouth Satellite 383/325 HP '383 Super Commando'
3.23 Gears, 4-Speed
#3480 lbs. ~ 325 HP = 10.71 Wt/Hp
Performance = 15.70 @ 91 MPH
A-Body
B-Body
Any idea how the A-Body could be rated higher in 1969?
Yes,
The 1969 A-Body 383/330 HP came through with,
* Improved Exhaust Manifolds
* Improved Exhaust Piping
* The 68' and 69' 383 Engines had a positive piston deck height
* #2843906 Cylinder Heads with 2.08" Intake and 1.74" Exhaust
* Improved Intake Manifold
* Carter AVS Carburetor (625 CFM)
* The 440 Camshaft and Valve Train
The 1969 B-Body 383 Engine (non Road Runner, Super Bee and Charger) had all of the
above, except did not have the 440 Camshaft or Valve Train.
Yet, the Horsepower ratings from the factory were both the same 330 HP, yet the
NHRA did not agree with their adjusted numbers.
If you look at the numbers, the 1967 B-Body exhaust system was a +15 HP improvement over the 1967
A-Body exhaust system.
In 1968, with exhaust system improvements - the A-Body was still -3 HP short of the B-Body 383
exhaust system output.
In 1969, the A-Body 383 was now equipped with the 440 Camshaft and Valve Train, which increased
Horsepower by +14 HP over the Stock 383 Camshaft and Valve Train.
.425 Intake /.437 Exhaust ~ 256/260 Duration ~ 32* Overlap
Valve Springs = #134 lbs. Valve Closed / #208 lbs. Valve Open
.450 Intake / .458 Exhaust ~ 268/284 Duration ~ 46* Overlap
Valve Springs = #129 lbs. Valve Closed / #280 lbs. Valve Open
Note; The NHRA lists the 440 Camshaft at .455 Intake / .470 Exhaust
Teak,
The exhaust piping for the 1967 383 B-Body.
Primary piping................2.25"
No flat spots in piping
Tail Pipe.......................1.88""
Teak,
If you look closely at the undercarriage of a 1967 383 'A-Body' exhaust system, you can see
the bends in the 'L-Angle' coming down from the exhaust manifolds.
The primary exhaust pipe had a listed size of 2.25", but those bends 'crushed' exhaust flow.
It was like jamming a 'half-a-potato' into the primary exhaust pipe.
