norshorblufish
By the Big Water
If you had power for your lights before and don't now you definitely have an electrical problem also. A busted rod won't cause that. Some of the members have good ideas of what to check as far as electrical. There is what is called a fusible link which acts as fuse for your electrical it could have gone.
The oil pan could also be dropped to see if there are any pieces of broken rod or other metal in it, but that doesn't always occur.
All you can do is check things out the best you can. Start with the simple stuff and work your way from there.
