mopowers
Is it true that Standard Mopar orange boxes pull out timing under high load? What about standard parts store 4-pin HEI modules?
I have heard the term :"pull out dwell", associated with FOB ignition. But like nearly any single coil ignition, at high RPM, dwell time decreases.
How much is pulled?Simple answer is Yes, they have been known to pull timing at higher Rpm.
How much is pulled?
