[WANTED] triangle alternator bracket
j par
Well-hung Member
Portland Oregon
Building a small block and I have the adjustable arm part but not the triangle piece that comes off the passenger side ofthe water pump. Thank you..
Are any of these what you are looking at? These are left over from my 69
I've always been able to make whatever I have on hand work with different length pipe spacers and/or washers to align the pulleys. Edit- as I've found some of the alt brackets have different offsets.
I actually just dug out a few more brackets and some other brackets he'll probably need for kickdown linkage for an automatic. Thank you for everyone's help you guys are awesome and if there's something in there that I'm not using and someone needs it go ahead and speak up.
