moparvinny
I have 69 date coded (11/21/69) 340 block for sale. Included with the block are the stock pistons, connecting rods, crank, and heads. The heads were recently reconditioned and machined for Teflon seals, resurfaced including harden seats and guides. Casting Number: 3671587. The intake size is 2.02 and exhaust size is 1.60. Cylinder head volume combustion chamber is 68. New comp valve springs, dual, 1.437 in. outside diameter, 402 lbs./in. rate, 1.020 in. coil bind height. The heads are ready to be bolted onto the block (after confirming heights, etc...). The engine block also includes a forged crank. When the engine assembly was torn apart, there were NO signs of coolant in the oil pan. The block has not been machined, bored, etc...
The overall vehicle restoration project direction changed and a stroker 340 short block was purchased along with aluminum heads for the Mopar. Therefore these parts are collecting dust and must have a new address.
Price: $1,400.00 obo
I'm working on gathering photos.
I can deliver to Milan (7/22), Norwalk (7/29) or Columns (8/12).
