I have a 69 dart console and 4 speed console shifter what I need is the shifter mechanism and mounting bracket that attaches to transmission and shifter rods are these parts different from non console cars think I have ever thing else
thanks I'm slowly accumulating the bits and pieces think I'm down to the mounting bracket and shift rods nowThe only difference on the console 4 speed cars is the shifter handle.
If it's like mine, there is no mounting bracket. The shifter mechanism bolts directly to the transmission with two bolts. Console shifter handle has a different bend to center it up in the console better.
If you have any trouble finding the parts you need, call Brewers Performance. They set me up with everything I needed to get mine back up and running.
You may want to take a closer look at your shifter mounting. The adaptor plate has 3 bolts holding it to the tail housing of the trans. and the shifter has 2 bolts holding it to the adaptor plate. You can't mount the shifter without the plate...
think I saw a repo kit on ebay that has bracket bolts and rods with fastners which would complete mineGood point! The adapter plate must have already been mounted on my transmission when I put mine back together. Thanks for catching that!
