Well that sucks! Didn't think about that.It says it wont work on the rear with double weld.
Funny tho, the brakes work ok! Wilwood on the front.O AND, while bleeding the rear brakes, I find out the guy who installed the brakes on resto, connected the rear brakes to the reservoir that is supposed to feed the front brakes on the master cylinder!! He connected it backwards!!! And of course, the fittings are different sizes. So I can't just change positions.
hmmmIt says it wont work on the rear with double weld.
Just pull the trigger. I ended up buying a pair of Vintique rallys for my Swinger just so the argent would match the rears.I should just buy the wheels with the the 4.5 backspace!
I still am in sticker shock on the price tho.Just pull the trigger. I ended up buying a pair of Vintique rallys for my Swinger just so the argent would match the rears.
Over an inchBut how close are you on the inside( leaf springs)?
i wouldnt.Think I can machine 1/4 off the inside, mounting surface of the wheel? Weaken it too much?
Nope, can't do that. Not thick enoughThink I can machine 1/4 off the inside, mounting surface of the wheel? Weaken it too much?
Yeh, NO. That just sounded like an INCREDIBLY Bad idea.Nope, can't do that. Not thick enough
I use an old Faithful gun. I bought my Remington Model 722 257 Roberts when I was old enough to hunt. The old girl has killed many o deer and other critters.I haven't yet. This is the first year in Indiana that we can hunt with high power rifles since the 1920s. , there are some limitations by caliber but Grendel is on the allowed caliber list for this year. Our limitations are a .243 diameter bullet and a min/max case length of 1.16/3.0 inches. Grendel specs out to a .264 bullet and a 1.52 case length. And I'd see the game warden coming long before he'd see me.
It's built very well and it'd take the rain just fine. but I dont wanna get it wet.
I wonder if that could not be doneAsk for the ones that bend the opposite way...makes tying your shoes easier!
Might it be worth a few calls to brake companies. Its the same casting as the SBP, so maybe they' would drill the drums for BBP. I suppose with a mill and a fixture you could have the SBP redrilled. Fred Puhn shows racers doing crazier drilling in drums - right though the contact surfaces.This started by changing out the axles and brakes, to get rid of the no longer available 1 1/2 brakes.
Well it's confirmed,both knees are bone on bone :-(I wonder if that could not be done
I've been telling people for years I'm a black women trapped in a white mans body.White person claims to be 'transracial,' identifies as Filipino
was wondering how long this would take
