Hey Chris
Exactly what i was thinking.you try it and let us know..Any one ever try plastic dip on the wire tabs on a firewall? Kind of wondering what to use.
I think that's what @CudaChick1968 uses on here valve cover wiring tabs.Any one ever try plastic dip on the wire tabs on a firewall? Kind of wondering what to use.
I don't remember if I put any on those. I think they were just paited body color. but basically same thing... Made these from sheet metal and coated to replace broken plastic ones.Any one ever try plastic dip on the wire tabs on a firewall? Kind of wondering what to use.
I did that...I had the dip stuff and the spray stuff, if I didnt remove the clip, I taped it off. Works fineAny one ever try plastic dip on the wire tabs on a firewall? Kind of wondering what to use.
Thanks just looking ahead a bit, nice to have it all on hand. Not removing the "tabs"I did that...I had the dip stuff and the spray stuff, if I didnt remove the clip, I taped it off. Works fine
yepPlasti dip? Looks like what I want.
I have real good success with Windex and a soft fine brass brush, then Armor-all.Plasti dip? Looks like what I want.
But that is actually dipped. Not sure if you can get it to look like that painting it onPlasti dip? Looks like what I want.
Thinking the dip stuff, also have a few other things to do. Trans line brackets, under dash clips etc.But that is actually dipped. Not sure if you can get it to look like that painting it on
Oh - you mean THOSE things. Panel-bond works immaculate.I don't remember if I put any on those. I think they were just paited body color. but basically same thing... Made these from sheet metal and coated to replace broken plastic ones.
Anything that can be removed, it works good. I suppose you could get smooth painting it on if thinned. Otherwise spray, but then need to tape /cover things good.Thinking the dip stuff, also have a few other things to do. Trans line brackets, under dash clips etc.
Coating the tabs?Oh - you mean THOSE things. Panel-bond works immaculate.
I can prob dip them, they are easy to bend down and no engine right now.Anything that can be removed, it works good. I suppose you could get smooth painting it on if thinned. Otherwise spray, but then need to tape /cover things good.
As a coating?Panel-bond works immaculate.
Gold?Dip is on its way. Have some tools that can use it also.
Yeah. Like for instance I did these. Blurry pic but you get the idea - Just kinda goop it on quick and spread it around with your fingers and rubber gloves. It self-levels real nice and smooth and shiny and it's never coming off.As a coating?
Morning, don't think I would take the chance this year.Hey who is still planning on going to Carlisle if it happens in July? Still on the fence with it.
