Ozzy
Hey guys! I'm looking for some answers, and hoping you all can help me out. I recently switched to electronic ignition on my 67 Barracuda, and I'm having troubles tuning her 318 back in. I did some research on the engine numbers, and the 318 is a 1975ish with 360 heads on it. It has a Holley high rise and 4 barrel, 4 speed trans.
Now that the new distributor is in, it doesn't want to time up. I put the light on it, and it wants to run way off time. Like, way off. I set the idle for 2000rpm, and look for my line. But when I turn the dist. to line up with the scale on the pan, it goes way advanced and fires out the carb. If I dial it down to where she'll run, the line is nowhere in sight. There are three lines on the balancer, but 2 only go half way across. I'm assuming the full line is the timing marker.
Any thoughts would be appreciated.
