My*65*Dart
I have a stock 1986 318 4barrel that I pulled from a police car. Does anyone know if these had different cam or heads from another 318 from that year? Thanks.
Heres a site that may help.I have a stock 1986 318 4barrel that I pulled from a police car. Does anyone know if these had different cam or heads from another 318 from that year? Thanks.
Sadly, when they reported that the 360 had a forged crank, it makes me wonder what else they don't have right.Heres a site that may help.
Cheers!!
1982-1989 Dodge Diplomat / Plymouth Gran Fury Police Cars - Code 3 Garage
Here's what I read about it George.There is some talk that the 1986 Police 318 used a spread bore intake with a Rochester Quadra jet mating up to 360 heads.
This sounds like a large port arrangement.
Now here is the thing with the 360 heads they have the small push rod holes as compared to the 302 closed chamber heads (roller lifter engines) larger push rod holes to allow more swing for the taller roller lifters/push rods on the roller lifter engines.
Would be interesting to know if they used the 318 roller block, or the regular 318 LA hydraulic lifter block for the police application?
The thing is if they used the large port spread bore intake and the large port 360 heads on a standard LA hydraulic lifter block, then I would say dollars to doughnuts it would have the 340 cam, same cam that came in the 360 Truck 4 barrel engines.
Do not believe they had anything equivalent to the 340 cam in a roller cam at that time. Would have had the stock roller 2 barrel cam for 1986. Although this roller 2 barrel cam does very well with a 4 barrel on top of it.
_____________
Will be very interesting to see if they used the roller block or not for the Police 318 in 1986?
The 302 is closed chamber small valve and small ports and the 308 is open chamber with bigger ports and bigger valves.Isn't there a "sister casting" to the 302 but for a 360?
I want to say "308".
Other Police Car Specifications Not Found In Civilian Models:
Engine: The engine should be a 318 with 360 heads, four barrel intake manifold, heavy duty exhaust manifolds, double roller timing chain, hyperutectic pistons, special piston-to-block clearances (allowable by use of the hyperutectic pistons), heavy duty chrome plated oil rings, forged steel connecting rods, heavy duty valve springs, high strength rocker arms, high temp cylinder head cover gaskets, high temp valve seals and shields, lubrite treated camshaft (4bbl hydraulic version had 430/444 lift with 268/276 duration, roller version had 391/391 lift with 240/240 duration), nimonic exhaust valves, special kolene cleaned cylinder heads, special silichrome-1 temp steel intake valves, and a heavy duty water pump.
Transmission: Transmissions will range from the heavy duty A727 (definitely available in 1983 and probably later as a special order), the 5-clutch A998 or the A999 (based on the A904). Some police cars may have 1st gear locked out (i.e. no manual downshifting to first gear – only automatic downshifting). This was done by Chrysler to prevent police personnel from slamming down into first to slow down quickly after a high speed chase and to prevent them from doing the same for quicker acceleration thus over-revving the engine. The lock-out may have been removed when the car was prepped for sale to the civilian market.
Suspension: Police cars came with stiffer suspensions and heavier sway bars than civilian versions. Some police cars may also have solid cast iron K-member isolators rather than the civilian rubber ones. This makes the ride somewhat harsher than their civilian counterparts, but greatly improves handling.
Differential: Police cars have the 8-1/4″ differential with Sure-Grip, and should also have the 2.94 gears unless otherwise ordered or changed. Civilian models have the 7-1/4″ rear ends without Sure-grip and much lower gear ratios.
Rear Axles: Police cars have single-diameter axle tubes. Civilian models have the lighter-duty axle tubes that narrow in diameter as they get close to the differential.
Tires: If they haven’t been switched, police cars will have wider performance tires. They usually came with Goodyear F32 P215/70 R15 tires.
Wheels: Police cars have 6 slotted 15×7″ steel wheels with 4.5″ bolt circles. Hub caps will usually be the small “dog dish” type that snap onto the center of the wheels.
Brakes: The brakes will have 11″ drums. Civilian versions) are 10″. The only exception to this are taxi packages, which will also have 11″ drums.
I can't help but to giggle every time I read "manual" fuel pump. It's mechanical not manual as in man hand operated.Yep, 1986 318 had the 302 Closed Chamber Heads.
Along with those it was a 9.2:1 cr Roller Lifter block.
Good chance it has the eccentric at the cam sprocket to drive a manual fuel pump too.
Yea, they definitely got that one wrong 66fs!Sadly, when they reported that the 360 had a forged crank, it makes me wonder what else they don't have right.
Still no OP since when the thread was started. We're just wandering around talking to ourselves.![]()
I went through an 85 or 86 police 318 for a 91 truck one time. It had the quadrajet carb with open chamber 360 heads. 345 or something casting number. The pistons were a little closer to the deck than a normal 318. It was a roller cam block with a flat tappet cam in it. I put it in the truck with the TBI and it was a real turd until I put closed chamber heads original to the truck back on it.
Im pretty sure it had never been apart. If i remember correctly the heads had the large push rod holes required for the shorter roller push rods, but like i said it had the regular flat tappet cam. The bosses required for the factory roller lifter hold down deal where present, drilled and tapped.
