...and a GOOD shop can do it in less than 15 minutes.It is an alum rad. You can have the top rad hose fitting moved to the side...& have a plate welded over the existing hole.
Yes, the kickdown linkage should look like this - and it should have a light spring to pull it forward (you can see mine just under the kd rod. The way the OP's is hooked up, the kickdown cannot possibly be working right, and maybe not at all.
Not that it will be "perfect" yet, but all the necessary parts delivered today...16" Flexfan and custom Thermostat housing.Oof. When I bought my dart, the linkage was screwed up like OP. I fixed it fast, but the trans (904) still failed less than 200 miles later when the clutches welded together.
I hope OP has better luck, but he needs to fix it ASAP.
DID YOU NOT READ THIS THREAD??Not that it will be "perfect" yet, but all the necessary parts delivered today...16" Flexfan and custom Thermostat housing.
I can fix the small stuff myself.
Would still be searching for a location for the temp sensor on the 318 block, lower; or even something like the lower rad hose.
Any other ideas?
Any other ideas?
Why the reference to the trans linkage????I would make sure the trans linkage is fixed before you so much as put it in gear again. It's that big of a deal. Unless you're already planning to overhaul or replace the trans?
because we can see it's out of adjustment and don't want you to roach your transmission.Why the reference to the trans linkage????
Any other ideas?
Pictures were provided. See the first page.DID YOU NOT READ THIS THREAD??
YOU DO NOT want to put a temp sensor in the LOWER hose, and there IS NO place on the block
The lower hose/ inlet side of the pump is all the "colder" side of the cooling system. You want to measure up top where it has been heated. GM put the sensors in the head starting?? in the 70's ??
Look, you have provided no photos of what you are up against. What brand is the gauge and what do you have for probe adapters? Some gauges can be adapted down to 3/8 pipe thread (about 5/8 OD) but I don't think they can be smaller, for mechanical ones.
Any other ideas?
We couldn't find another location for the heat sensor.
The have ordered a different thermostat housing.
Yes, planned on getting rid of the acordian!
They mentioned a shroud. But, we''ll have to follow temps after the things we are already doing.
Ordered a 16 inch FlexBlade from Summit Racing.
(These things will hopefully keep us from having to lift the rad, as that would have been overall more expensive to do. And not sure what interferance that would create.)
Yep, that's F**ked up. It looks like a GM guy put this one together.I'll reiterate to fix kickdown 1st.
Thanks AbodyJoe!maybe something like this? Allstar Performance ALL30375 Allstar Performance Water Neck Spacers | Summit Racing
Well, you've been asked what kind of intake manifold you have. Crickets. That could help us help you. You asked for help. People who don't even know you and are not being paid one red cent for their time and experience are reaching out to try and help you, but you're calling us picky? Might wanna rethink that and start answering pertinent questions if you want help. You have a lot of correcting to do and we can help, but you need to be respectful of those trying to help.Thanks AbodyJoe!
That is exactly what I had posted a link to a few posts back.
But the picky people are just picking away without looking at the the Thermostat spacers with ports for sensors fix that I had posted a link to earlie - which is a historic thread from this very Forum. It just takes a while to finds these kind of discussions.
Vintage Air 706001-VCQ Vintage Air Water Neck Risers | Summit Racing
Thanks AbodyJoe!
Indeed. At this point, I say let him go forward in his own ignorance and burn the thing to the ground. I drove Vixen today and she runs fantastic!I don't think anyone has rejected the spacer as a workable solution; in fact several have recommended it (including me, although I also suggested a cheaper solution). What we have been picky about is your insistence on raising the radiator instead of simply moving the upper radiator hose fitting to the correct spot, your insistence on looking for a place to mount the temp sending unit on the block or in the lower radiator hose despite our warnings that those are not good places to try to mount the sending unit, your rejection of our advice not to run a flex fan, and your rejection of our advice that you absolutely need to correct your kickdown linkage.
I wasn't gonna post any more, but calling US "picky"?![]()
There's so many people that like the "idea" or like a "look" but on the functional side don't get executed too well.I know that somewhere along this saga with the new to me 1967 Barracuda I have questioned ya'll about the proper thermostat temp for a 318.
The consensus was 180 - 190, so I had bought one to include in my latest list for my fav dealer.
The old man and son who put this 318 together were clowns! And it's beginning to get frustrating dealing with all the fixes.
("Cobbled together" someone else posted, is corrcet!)
**Well so today, the shop shows me that there is no thermostat in the housing!!!!
The old man liked the aftermarket gagues under the dash. But....the sensor probe for the aftermarket temperature gauge sticks so far into the housing that there was no room for a thermostat.
**SO THEY LEFT IT OUT!!!! REALLY???
I can only assume that since his intention was to only drive short distances to local shows, that he wasn't concerned about it! And didn't tell me about it! No wonder I can't get any heat!
But, when we looked closely at the hose coming off the radiator, we discovered what the rattle noise was that I had them looking for.
The fan blade - hitting the hose - almost all the way through.
I'll be ordering a shorter fan blade. But because the end of the radiator nozzle is sooo close to the fan blade, I may need a modified hose too.
The other option is more extensive - cutting some extra holes in the radiator mounting and raising the radiator an inch.
