MOPARCODY
up for sale is a 383 that came in a car i bought years ago, the car was done by a high school for the high school drags. the body was pretty rough so i parted the car out took all of the suspension for my car but i have no use for a big block
383 block
440 crank
516 heads
edelbrock tourqer intake
holley 750 vacuum secondary carb
mpp distributor
belden wires
was told it has a purple shaft cam in it, not sure which one
mopar performance aluminum valve covers
aluminum water pump
motor is brand new, we ran it in the car several times, never drove it on the street
it sounds like it has a lot of compression but im not sure what ratio it is.
im asking 1500 picked up
ill throw in a tq727 trans which is fresh and has a 3k stall converter
383 block
440 crank
516 heads
mpp distributor
belden wires
aluminum water pump
