Eworth
Hello,
Have a 1964 Dart.
The dimmer for the instrument gauges never brighten the gauges enough that I can see them well. I have hooked up new mechanical gauges under the dash and put them on a separate toggle to turn those lights on.
Can someone explain how I can bypass the dimmer control at the headlight switch and how to put my dash lights on a separate toggle switch?
What wire/where do I cut/disconnect to eliminate the dimmer. And what wire/where do I splice to have control of the dash lights so I can place a toggle in that location?
Thanks in advance!!
Mark
Have a 1964 Dart.
Thanks in advance!!
Mark
