Thanks for the reply, I need black, I guess I could dye them, mostly interested in the floor location for the anchors and anchors, none were ever in the car. Send some pictures of what you have please. Thanks a bunch....I am sure I have a set of seat belts for a 66 Dart. They came out of my 270 Dart. They are red. I have no use for them. Let me know if your interested or need pics.
Rod
Anchor location and anchors would be great! Thanks I will get the PM out sometime today...Give me a day or 2 and I will get you some pics of the belts. I did a mini tub on mine and I cut out the anchor section. I just cleaned up a lot of the old stuff I had laying around for a year or so and I think I may have thrown out the anchor section but if not you are welcome to them. Pm me your email so I can get you the pics.
Rod
Your inbox is full, I am just interested in the seat belt floor anchors.. ThanksAnchor location and anchors would be great! Thanks I will get the PM out sometime today...
I guess, the car never had them, there are no holes for them. Location is a problem also, looked them up in shop manual, hard to tell by the picture... ThanksWhen you say floor anchors are you referring to the bolts to fasten them down?
Rod
Thanks for all the effort, I actually found the holes they were plugged. I thought I had posted that somewhere. Again thanks...this is my 66 convertible. they had seat belts in the rear.
the darker section is a 72 dart floorpan modified in the front seat area to use 97 sebring seats front and rear but the spotwelds are the same as the original 66's welds. car is on a rotisserie and flipped on it's side to view the undersidein pic #1
ignore the second arrow pointing to the rear there is only 1 hole in side of the rocker panel that is threaded.
this is the top view of picture number 1
hope this helps.
