Moparparts
FOR SALE: This is a nice used, older, Very Heavy Duty Built Accessible Systems Bottoms Up Lift Rotisserie with 16 inch high pneumatic tires and 2) 3 ton long ram jacks with extensions for higher lift on wider cars...It is an older tow-able model with tongue and loop that was listed as a 3000 lb, but according to the manufacturer's specs, can handle 5000-6000 lb, as it was built from heavier steel pieces than the 3,000 lb ones that are available now...It is in bare steel and is not rusted up or damaged, and has always been stored inside...I had some extra bolt supporting done to it back when I purchased it...The tires are not dry rotted or cracked, but some will need aired up...Price is about half of what it would cost to have one built to these specs, with today's price of good steel...The pics of it apart, are the current pics of the unit...The pic of it together is from years ago. Price $1200.00. Pick up only from Pa 17086. Post or message if interested.
