moparenthuz
"Badass Swinger"
Definetly go efi. Its in the budget and worth the performance.
Would i have to cut my floor up to fit the A518?Go Street EFI 400 HP – FiTech Fuel Injection
Dodge A518 Super Duty Transmission | Mopar Automatic Racing Monster Transmission
BluePrint BPC4082CT Chrysler 408 Base Engine, Cast Iron Heads
Haha about $7600 you can have overdrive fuel injection and modern performance numbers.
Not to my knowledge. I wish had one in my car to tell you. I'm sure someone here knows...Would i have to cut my floor up to fit the A518?
To me that basically means not an engine that would produce results such as 8-12 mpg, i want more efficiency
Do magnums get better mileage than the la 360's? head to head are magnums generallt more effiecient?
Thanks for the insight and info i really appreciate it, also where you say "good gearing" and "machining, assembly, tuning, done right" can you give more specifcs on what that would be to give me an idea on what to do for my build i want gearing to have decent get up and go in the city without sacrificing highway mpgs and as far as machining and assembly what should be done? Over bore . 30? Zero deck?The reason you see terrible gas mileage in the Magnum-powered Jeeps is because the drivetrain is very inefficient and they are big, heavy SUVs. The Grand Cherokees that came with Full-Time 4x4 had a viscous coupling between the front and rear driveshafts (kinda like a torque converter), I'm sure you can imagine what having essentially 2 torque converters to push power through does to fuel economy. Those transmissions were never very efficient either, some guys on here with A-518 swaps are getting a few better MPGs but their drop in 1/4-mile times says a lot about power being thrown away. Manual transmissions FTW when it comes to gas mileage.
With regards to weight and especially emissions affecting gas mileage... A modern 5.7 Hemi Challenger weighs a hefty 4200 lbs and typically get low 20's/high teens MPG average with mixed driving. People who have swapped 5.7 Hemis into their classic Mopars that typically weigh at least 500 lbs LESS and don't have to worry about emissions are averaging mid to high 20's, slightly less if they didn't use an O/D trans or tall gears.
Since my 360 broke I'm going to build basically a 318-based version of the same thing and just swap over the stock Magnum heads, Air-Gap manifold, get a good modern street cam in the 220-230* @.050" range, put in some KB hyper flat-tops and top it with a 600 cfm Edelbrock or maybe Street Avenger Holley if I can find one for a good price. This combo is nothing new and is proven to make around 300 HP at the crank if done right (machining, assembly, tuning) and with good gearing 20+ MPG, at least on the highway, should be no sweat.
Sounds like its gonna be a sweet build! Is there a lot of fabrication involved in putting the tranny in your a body?? How are you going about doing that?I'm putting together a 340 with ported Edelbrock heads, Comp 222/230 .538/.534 lift hydraulic roller cam, drop in lifters, Super Victor EFI intake, FAST 4150 throttle body, & FAST XFI Sportsman EFI, backed with a Tremec 3550 5-speed. It's going into a 72 Duster 340 clone with 3.91 gears! Engine is at the machine shop. Hope to have it ready by summer!!
