Hi all,
I just put my new engine together:
1976 360 block 0.30 over
Scat cast steel crank
Scat I-beam rods
+5cc flattop pistons
windage tray
Melling HV oil pump
Rapom alu heads 2.02 intake 1.60 exhaust valves 65cc
Comp hydraulic flattapped xe274 cam
Edelbrock air-gap intake
about 10.6 to 1 compression
Hughes 2500 stall converter
TF-904 reverse full manual valve body
8 3/4 with 3.23 to 1
Car is 1974 Plymouth Scamp
and its still running too hot (yes i checked with infrared too) on hot days up to 250 degree...
what i did until now:
Checked 180 degree thermostat - works fine but i throwed it out think i had trapped air in the motor (already heard something about drilling a little hole in it??)
Changed the 26" griffin aluminium radiator with the original one - no improvement
Changed the milodon high volume water pump with the original one - no difference
Spring in the lower radiator hose
throwed my custom made fan shroud out
Has now only an electrical fan behind the radiator but i think when the car is moving it should work without a shroud (heard even without a fan because the fan is only for cooling when the car is not moving?)
The motor is running hot even when im just cruising down the street with nearly no throttle
Carb is a holley 650cfm DP now with bigger jets from a 750cfm hp main body because i thought it was too lean but also no difference still running hot
Any ideas what i should do next??
Thinking of an engine oil cooler just have the stock oil pan but with a dual oil filter relocation kit with two tall filters??
Thanks, Laurin
Scat I-beam rods
windage tray
Melling HV oil pump
Thanks, Laurin
