Stop in for a cup of coffee
but when she quit the job she had I told her I would support her decision 100% - and I did, even when she got cranky and was down on herself for quitting the job.. nothing was coming to her but interviews and "thank you for applying but"... the really tough ones were the jobs she really wanted and was told she was their 2nd option and they would let her know if the person they had decided to hire didn't work out... WTF, do you think I am going to wait for 6-12 months while you think about this!!??
There's plenty of rotary switches with 10A breaking capacity, but they're all the bulky, industrial cabinet style, like the kind you'd use on a theme park attraction. :)
I can help you look! It's a monumental jungle.
Just use relays, then whatever switch you find will work.
That's what I'm thinking too, but it takes more wiring.
i'm not opposed to wiring if I know what it is that needs wired and how lol
So you are trying to switch between two tanks each with their own pump? Momentary is going to spring back to the off position when you let go, so can't see that working.
I could wire a relay to work like that.
i didnt realize it was momentary lol. I'll keep looking. and yes, each with there own fuel pumps.
It needs a 15A fuse, so my guess is in the 10A range. I think a couple of relays is the best solution. Then there are plenty of stylish switches to be found. I need to make dinner now but I'll be back!
thanks!
And you want an off position for?
didnt know i could get a switch that didnt have one?
Just need an A/B switch
hmm ok
because he's a control freak - :lol:
haha
I have a switch in my hand that will work for you. On to the left, left off to the right, right on. Right off to the left. left on.
Yeh, don't see a need for that either.
Not sure deciphering there data sheet... I think this one functions as an 'A/B' with no center position. For some reason they downgrade it to 8A for DC? They make this with just about any configuration. With or without center. Any position NC or NO, Momentary or not... I would call them and be sure I got the right one
