evans68cuda
Hey everyone, my battery died over the weekend on my 68 barracuda fastback a few weeks ago so I tried pulling fuses to see whats goin on. With all of the fuses in, I am getting a 1.3 amp draw, and once I started pulling fuses out, I found it was the dome lamp. With the dome lamp fuse out I get .02 amp and Ive heard that these cars should be good with anything less than .1 amps. Now, I currently do not have a trunk light so that is why I am thinking it could possibly be the culprit. I disconnected the wire from the cigarette lighter and still pulling 1.3 amps. both of the lights next the the rear windows turn on when the doors are open and turn off when they are closed, along with a courtesy light under the passenger side of the dash. Not sure if there is supposed to be a light under the driver side dash, but currently there is not one, along with no trunk light. I was looking at the 68 Plymouth diagrams and it shows a trunk light switch and light breaking off from the 2 dome lamps, but I do not see any loose wires in my car. Any ideas?
