Magster65
Will this fit under the hood of a 67 Dart? It looks tall...
Is that an Air Gap? I have an Air Gap on my 69 340 Cuda with an Edelbrock Thunder carb, and it fits under the hood. I did have to buy a 2" high air cleaner element to replace the 3" one, but it fits.
Tim, that looks sharp. What color is the engine bay? It almost looks like the orange the newer power wagons used. Sorry to get off topic.
And the Holley is shorter then the Carter. Where the air cleaner sits.I don't know if Dart's and Cuda's have the same hood height but I have an Air-Gap on my SB with a Holley on top of it WITH a 1" spacer and it clears the hood (just barely). The trick is to find a drop base air cleaner. I got the air cleaner with the most drop there is. The drop base cleaner barely clears the carb but it gave me a lot room to the hood. BTW: it's a 3" tall filter element on it too
I didn't know that. Do you know how much? I haven't measured them but have had them sitting close together on the bench and never noticed itAnd the Holley is shorter then the Carter. Where the air cleaner sits.
