HemiMark
Can anyone tell me what is the tallest tire I can use on a 68 Dodge Dart? Is 26 to 28 inches possible?
It's a combination of tire width, rim width, and rim backspacing.
Some ideas of those variables would help
I'm using 15’ Cragars.It's a combination of tire width, rim width, and rim backspacing.
My Lord, Its like I'm retarded.
15' Cragars, 4.5' wide with 2 1/4' back spacing. Yes, I am looking to run narrow tires that are highway safe. Radial for sure. Sorry for all the vague and scattered post's!
I've run 215/65s and 205/75s on my 68. Both fit fine. The wheel I used was a stock 15" steelie- 5.5" wide if I remember correctly, but don't quote me on that.
Problem is that even a 205/75/15 isn't supposed to be mounted on anything narrower than a 5" wide rim. And the stock steelie's have a +6 offset, so, they have significantly more backspace than the OP's chosen rims and will be further inboard, which allows for a taller tire.
