Mopar mopar forum
 HOME  FORUMS   MEMBER PHOTO GALLERY  CHAT    REGISTER  FABO STORE
 MEMBER CLASSIFIEDS  VIN DECODER  VIDEO GALLERY
Our Network:  B BODY MOPAR FORUM  C BODY MOPAR FORUM  E BODY MOPAR FORUM  FMJ BODY MOPAR FORUM  CAR AUDIO TALK  PICKUP TRUCK FORUM  FOR JEEPS ONLY
Go Back   For A Bodies Only Mopar Forum > Automotive Technical Forums > Forced Induction Mopar
Optimum exhaust manifold?
Thread Tools Search this Thread Display Modes
Old 10-10-2011, 07:07 PM   #1
ZZ.au
Junior Member
ZZ.au's Flag is: Australia
Heyas.
Been collecting parts for a turbo setup for my Aus A body and have decided a set of magnum manifolds would be best.
These are quite rare in Australia (none sold down here).
Clearance on components shouldnt be an issue I imagine as they will need to be swapped left/right, ending up facing forward.
I have narrowed my choices down to the 92-93 dodge/jeep manifolds with the 2.125" exits. Would these manifolds flow about the same overall? Are the jeep units the same on the exits? I have read a few posts that indicate they are anywhere from 2.5-2.25", but I have no way to check for sure.
Thanks in advance.
ZZ.au is offline   Reply With Quote
Old 10-10-2011, 08:59 PM   #2
CUUDAK
Senior Member
CUUDAK's Avatar
CUUDAK's Flag is: United States
That or you can use the afforable block hugger headers MadDart is using on his twin turbo setup.
CUUDAK is offline   Reply With Quote
Old 10-11-2011, 02:37 PM   #3
Mad Dart
On the Turbo Kool-Aid
Mad Dart's Avatar
Mad Dart's Flag is: United States
Quote:
Originally Posted by ZZ.au View Post
Heyas.
Thanks in advance.
I used the Hedman Block Huggers. If you go this route 1st thing you need to do is Throw the Reducers in the trash and make your own pipes. They choke the exhaust down at the collector to around 1.75" instead of being 2.5".
There are a TON of pictures in my build thread so you can get some ideas if you want.
Mad Dart is offline   Reply With Quote
Old 10-11-2011, 02:59 PM   #4
RustyRatRod
Senior Member
RustyRatRod's Avatar
RustyRatRod's Flag is: United States
Send a message via Yahoo to RustyRatRod
Louis, I know we've go after each other a little....but buddy, you do some fantastic work. Caint wait to see it run.
RustyRatRod is online now   Reply With Quote
Old 10-11-2011, 05:33 PM   #5
ZZ.au
Junior Member
I've been through that thread cover to cover. Killer stuff.
I have absolutely no fabrication or mechanical skills. Might be time to learn though.
I think my power goals are quite modest and would be comfortably achieved with the turbo I have (GT42) and the higher flowing (for manifolds) late(ish) model manifolds.
I do appreciate the suggestions so far though. Considering that the block huggers are available here and the manifolds would have to be imported, its definitely an option.
I would like a bit more info on the differences between the jeep and the dodge manifolds before I close the door on them.
Thanks again.
Old 10-11-2011, 07:09 PM   #6
Mad Dart
Mad Dart's Avatar
Have you tried theturboforums.com ?? You might find more information about using the manifolds.
Reply
Search this Thread:
Advanced Search
Display Modes
Fabo Sponsors
Powered by: vBulletin Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Page generated in 0.16589 seconds with 20 queries
