Tons Of Mopar Parts!!!
Mopar Mechanical Parts For Sale
11-06-2011, 06:55 PM
#1
Senior Member
I am cleaning house for winter and all of this, yes all of this must go! heres the list! thanks
duster, dartsport, demon complete clear glass minus windsheild-$200
Black Kick Panels, orig Nice-$30
Upper metal headliner hold down peices blue-$10
Sill Plates orig Nice-$30
New Milodon Windage tray 340-$40
New Crane Valve springs good to .525 lift-$75
Double Roller timing chain orig 340-$15
late 71 340 rods and pistons-$125
318 rods and pistons hd-$50
67-72 abody centerlink, blasted and painted-$25
73-up lower control arms rust free-$100
73-74 duster grille nice-$50
73-up bumper-to-grille metal filler rust free-$25
904 duster driveshaft-$30
73-up front lock support assembley-$25
Bumper jack assembley-$30
Duster, demon, dartsport fuel filler neck-$20
Single groove water pump and crank pulley rust free-$30
New Moog Idler Arm 67-72 A body-$25
New Moog Pitman Arm 67-72 A body-$25
A/C under dash vents nice-$20
New Rear Sump BB Mopar Performance Oil Pan and pic up-$75
A-body glove box door w woodgrain-$15
Blue stnd 3 spoke steering wheel and center cap nice-$40
Black steering wheel with large 3 spoke center-$25
Column shift steering collumn parts, everything except shaft-$50
68 barracuda floor shift collumn complete but apart-$100
68 barracuda black standard steering wheel, very nice-$100
74 A-body front bench seat white needs recovered-$35
74 abody battery tray-$10
340 oil pan pic up factory-$10
Big Block 73 Exhaust manifold, baffles have been removed and welded, sandblasted, port and polished, then proffesionaly sprayed w a cast iron appearing temperature paint-$300
Thanks for looking, all prices are negotialble and shipping will be as cheap as possible. Please send me a pm if interestead in any parts, i will give excellent deals if you buy a bulk of parts, thanks
11-06-2011, 07:04 PM
#2
Senior Member
hey are the 340 pistons standard size?
11-06-2011, 07:05 PM
#3
Senior Member
yes 340 pistons are standard bore
11-06-2011, 07:08 PM
#4
part numbers on the moog idler & pitman stuff? thanks Lawrence
11-06-2011, 07:28 PM
#5
Senior Member
pm'd
11-06-2011, 07:54 PM
#6
Need to join FABO rehab!!
PM sent and returned.
11-06-2011, 08:39 PM
#7
Senior Member
pm sent
11-06-2011, 08:47 PM
#8
Pikins, Slim Pikins.
I'm assuming this is for an A body? Got a pic?
I am definitely interested in it if it is.
11-06-2011, 09:10 PM
#9
Senior Member
kick panels
pm sent
11-06-2011, 09:21 PM
#10
'74 Duster 360
could you send me a pic of the black steering wheel and the 73-74 grille? What year is steering wheel out of?
Thanks.
Reason: added words
11-06-2011, 09:24 PM
#11
"New Moog Idler Arm 67-72 A body-$25
New Moog Pitman Arm 67-72 A body-$25"
You might want to recheck. The 67 idler is a one year only deal. Don't know about the pitman
11-07-2011, 06:52 AM
#12
70 Plum Crazy Dart
PM Sent
11-07-2011, 07:14 AM
#13
Do you have a part number or any more info on the valve springs?
11-07-2011, 07:23 AM
#14
Junior Member
I`ll take the fuel filler neck. sending pm
11-07-2011, 07:41 AM
#15
Senior Member
PM sent
11-07-2011, 09:04 AM
#16
Junior Member
pm sent
pm'ed
11-07-2011, 10:24 AM
#17
Junior Member
Sill Plates
PM sent on sill plates
11-07-2011, 03:37 PM
#18
WTH YOU LOOKIN AT??
pm sent
11-07-2011, 04:24 PM
#19
Senior Member
PM sent as well.
matt
11-07-2011, 06:08 PM
#20
Junior Member
Do you have any column shift linkage parts? I need the lower rod that goes from the shifting linkage to the lever on the transmission.
11-08-2011, 12:21 AM
#21
Senior Member
pm sent
11-19-2011, 08:17 AM
#22
anyone heard from this add? I've pm'd 2 x for the moog part #'s no response.
11-19-2011, 08:29 AM
#23
PM Sent
11-19-2011, 08:34 AM
#24
Quote:
Nope, never got a response.
11-19-2011, 10:01 AM
#25
WTH YOU LOOKIN AT??
I havent heard anything.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
