Mopar mopar forum
 HOME  FORUMS   MEMBER PHOTO GALLERY  CHAT    REGISTER  FABO STORE
 MEMBER CLASSIFIEDS  VIN DECODER  VIDEO GALLERY
Our Network:  B BODY MOPAR FORUM  C BODY MOPAR FORUM  E BODY MOPAR FORUM  FMJ BODY MOPAR FORUM  CAR AUDIO TALK  PICKUP TRUCK FORUM  FOR JEEPS ONLY
Go Back   For A Bodies Only Mopar Forum > Automotive Technical Forums > Mopar General Discussions
Parts Washer cleaner
Thread Tools Search this Thread Display Modes
Old 11-10-2011, 08:59 PM   #1
72ScampTramp
Scamp Tramp
72ScampTramp's Avatar
72ScampTramp's Flag is: United States
Send a message via Yahoo to 72ScampTramp
What do you guys use in your parts washers? Im thinking about making a homemade parts washer. I'm going to rebuild my transmission so I think water based is out.
72ScampTramp is offline   Reply With Quote
Old 11-10-2011, 09:49 PM   #2
greg r
Junior Member
greg r's Flag is: United States
Good 'ole Stoddard solvent is what I've been using. It's pretty close to being mineral spirits, and usually what's on the drum the guy pumps it out of for me. High flash point, fairly high vapor point so it doesn't evaporate very much. If you can rig up a filter to go with the pump, your "charge" of solvent can last a long time and with the hose or wand you'll clean the parts with clean solvent instead of recirculated dirty solvent.
greg r is offline   Reply With Quote
Old 11-10-2011, 09:58 PM   #3
RustyRatRod
Senior Member
RustyRatRod's Avatar
RustyRatRod's Flag is: United States
Send a message via Yahoo to RustyRatRod
I've tried most all of the environmentally friendly stuff....because let's face it, IF there's something out there that works well, it would have to be better for the planet. BUT, all I have found is stuff that works well for a very short period......it get's "loaded up" if you will with all of the grease that comes off stuff and looses it's effectiveness. I use straight mineral spirits now.....not the low odor stuff. Just good old make you have two headed babies mineral spirits.
RustyRatRod is offline   Reply With Quote
Old 11-10-2011, 10:12 PM   #4
earthmover
in the tire smoke
earthmover's Avatar
ive got purple stuff in my parts washer..got it in 2.5 gal jugs from lowes for a good price...
earthmover is offline   Reply With Quote
Old 11-10-2011, 10:14 PM   #5
RustyRatRod
Senior Member
Quote:
Yeah give it time. It'll load up too.
Old 11-11-2011, 09:27 AM   #6
OneOfMany
OneOfMany's Flag is: Canada
Quote:
A couple of cups of lacquer thinner mixed in to the solvent don't hurt either.
Grant
OneOfMany is offline   Reply With Quote
Old 11-11-2011, 05:13 PM   #7
cudamark
cudamark's Avatar
cudamark's Flag is: United States
The trouble with some solvents and cleaners is what to do with it when it needs to be replaced. Flushing it down the drain is usually a no-no and the auto parts stores don't want it mixed into their recycled oil. I use diesel or kerosene as they can be added to the used engine oil without a problem (so far anyway!) The down side is it doesn't dry to a paintable surface.....you have to remove the residue to get it clean enough to prime. That and the smell....ugh.
cudamark is offline   Reply With Quote
Old 11-11-2011, 06:22 PM   #8
godfatherofchry
Senior Member
godfatherofchry's Avatar
godfatherofchry's Flag is: United States
I use parts washer solvent 5gal.and 3gal of diesel fuel works good dries good after blowing And wen it gets dirty makes a good fire starter for burning tree limbs and brush............Artie
godfatherofchry is offline   Reply With Quote
Old 11-11-2011, 06:27 PM   #9
ramcharger
Dismember
ramcharger's Avatar
ramcharger's Flag is: United States
Quote:
Kerosene is really, really flammable. Like flash, whoosh flammable.
ramcharger is offline   Reply With Quote
Old 11-11-2011, 06:51 PM   #10
inertia
inertia's Avatar
inertia's Flag is: Canada
Use plain old solvent with a little ATF in it to make it a little kinder on the hands, BUT most helpful is about 2 inches of water in the bottom,, which the sediment falls into, and stays,, helps keep the "solvent" cleaner, longer.. my 2 cents,, cheers.. grant..
inertia is offline   Reply With Quote
Old 11-11-2011, 06:59 PM   #11
cudamark
cudamark's Avatar
Quote:
Since it was used for decades as a lamp oil, the flamability is at a minimum. It burns but doesn't flash like gasoline. It's not that much different than diesel.
Old 11-11-2011, 07:20 PM   #12
72ScampTramp
Scamp Tramp
Thanks for the input. Yes disposal is going to be tough. I dont plan to keep it around long just long enough to clean tranny parts.
Old 11-11-2011, 08:12 PM   #13
BillGrissom
Cheap Mopar Bastard
BillGrissom's Avatar
BillGrissom's Flag is: United States
I rebuilt 2 trannys the last year. I only needed to clean the outside. If the parts inside need cleaning, something sounds really wrong and they are probably severely worn. I don't have a parts washer. I just use small brushes with gasoline or diesel. Actually a mixture left from when my wife called saying "the car sounds funny". I said "smells like gasoline, did you remember to fill it with the green hose?" (diesel engine). Nope, so I siphoned out 18 gal. Big parts I clean outside. Small parts on a table in the garage. I put newspaper underneath to catch everything and change it regularly. Diesel works better since it sits longer without evaporating. Of course, don't smoke (ever, even when you not working on cars).
BillGrissom is offline   Reply With Quote
Old 11-11-2011, 08:16 PM   #14
72ScampTramp
Scamp Tramp
Well.... Its not that something is wrong.. But how can you check surfaces and look for wear marks without clean parts? I worked in a tranny shop in the tear down and clean up. Every transmission that came in got tore down and all parts were cleaned.
Old 11-11-2011, 08:24 PM   #15
cosgig
MoBro Inc.
cosgig's Avatar
cosgig's Flag is: Aaland
I don't know about other areas, but in my neck of the woods the oil change place I go to will allow me to dump anything I bring in down their drain basin. I couldn't believe it the other day when I had a couple gallons of used antifreeze and the guy told me to just dump it in where they drain the cars!! Mineral spirits are petroleum based if i'm not mistaken and could be added to used waste oil with no problems, at least at the place I go to!!! Geof
cosgig is offline   Reply With Quote
Old 11-12-2011, 05:41 AM   #16
cjh
Senior Member
cjh's Avatar
cjh's Flag is: Australia
AVTUR.....Aviation Turbine fuel.....in layman's terms....power kerosine, Jet fuel.....it will evaporate in about 10 minutes or so when new......and cleans well.
For really stubborn stuff, I use a water based degreaser.....it will take the skin off ya hands......and don't let alloy sit in it....it will eat it.....need to keep it moving and scrubbing.
cjh is offline   Reply With Quote
Old 11-14-2011, 10:21 AM   #17
BillGrissom
Cheap Mopar Bastard
Little parts, like from a carburetor, I soak in a special cleaning fluid you buy at auto parts. It comes in a 1 gal metal paint can w/ a strainer basket inside. I have also soaked pistons one at a time in it, with a plastic bag taped over (1 per night). It has something floating on top to limit evaporation. Smells nasty, but doesn't hurt aluminum.
Another idea is SuperClean, which you can buy at Walmart. I think it is a strong alkaline water-based solution. I used it to remove paint & chrome from plastic dash trim, which is an idea I found on plastic model web sites. Works great for that. Haven't tried on steel parts. I did hold down the plastic with an aluminium chunk and it attacked that, so don't try on aluminum.
Old 08-03-2012, 06:01 PM   #18
dustinmoran91
dustinmoran91's Avatar
dustinmoran91's Flag is: United States
Just mixed some solvent up from stuff i had sitting around, 2 gallons of b-12 chemtool, 2.5 gallons of parts solvent, 1 can aircraft stripper, 5 gallons of diesel lol i used a 30 gallon plastic tub and needed to soak a pair of heads and some other little stuff. Sounds like a lot but just barelt covered the tops of the rockers
dustinmoran91 is offline   Reply With Quote
Old 08-04-2012, 12:10 PM   #19
cudamark
cudamark's Avatar
Quote:
What are you going to do with it when it's spent. With that many different chemicals, it would have to be handled as hazerdous waste and cost a small fortune to get rid of.
Old 08-07-2012, 07:11 AM   #20
dustinmoran91
Lol it is hazardous, didnt wear gloves and it soaked into cut on my knuckle and after the intial burning i got where i could stand that so i washed parts for about an hour and for the last two days that knuckle has been swollen and sore beyond belief haha
Reply
Search this Thread:
Advanced Search
Display Modes
Fabo Sponsors
Powered by: vBulletin Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Page generated in 0.22733 seconds with 34 queries
