FABO Members finished A-Body Picture Thread
Cevidicus
CevidiGrinch
West Central Texas
Here's my idea... A thread for pics of finished members rides with no commentary or disscussions.
Post 4 to 6 of the best pics of your Completed A-Body from various angles (front, rear, L side, R side, interior, engine etc) with a very breif discription(tell what year, model, engine, trans rear gear or any special notes). If you have a build thread, please post a link to it as well.
All other posts / comments Like, "Sweet Ride, Dude!",or "I hate those 18" wheels." Etc will be deleted. If you want to pay your compliments to the owner, please post them on thier build threads or in a PM. (later, after several pages are filled I may allow posts with comments)
Only posts containing pics of your ride with very breif discriptions allowed.
This thread is intended to represent the Cars of FABO members and our site in general.
Thanks and if you have any questions or comments, please PM me.
----Note to those with unfinshed rides or projects. I will start a similar thread for you after this one gets going.
:burnout:
1971 Dodge Demon 340 tribute.
Built 360,727 tranny, 8 3/4 rear
3.55 sure grip,power disc brakes,power steering.
[/IMG]
[/IMG]
[/IMG]
[/IMG]
1973 Dart Sport, 512 big block based on 440block, 440source rotating assembly, Eddy heads, intake, Comp cams 567 lift hydralic cam, ProSystem 950HP carb. 727 trans with Mopar Performance internals with 3500 stall converter. Narrowed 8 3/4 with 4.10 spool. Mini-tubbed with subframes tied.
1971 Demon (started life as a /6) 1970 383, 727, 8 3/4" with 3.91 gears. Schumacher headers, mounts and torque rods, AAR hood, sub frame connectors, 2 1/2" exhaust. :burnout:
Demon 750 DP'r, RPM Performer, .509 MP cam, Hughes roller rockers and push rods, Pocket ported heads. HV oil pump and water pump.
Lots of parts off a '88 Gran Fury cop car...
75 Dart Sport 360, numbers matching, 72k miles, 727 with console/buckets/fold down rear seat, was stored for over 25 years. Vitamin C Orange paint.
I'm the second owner.
67 barracuda, org H code car. 499 stroker, 727, 3500 stall, dana,373 rear. 4 wheel disc brakes.
1971 DEMON
GY3 Courious Yellow
6.1 Hemi
833 4 speed
355 gear
17 x 7.5 2006 chrysler 300 steel wheels
275 50 17 rear tires
225 50 17 front tires.
!969 Dart Swinger original 273 now 340/727/8 3/4 3.23 sure grip. donor car was a 1971 Demon 340.
My Demon started life as a 318/904 bench seated little old ladies car in Quebec, Canada. It's a little different now-a-days. I finished it in 2007.
360 +.040
Magnum heads 2.02 int. 1.62 exh. Lots of porting
KB 107 pistons zero decked
10.58 to 1 compression cylinder pressures 190 to 195 psi
stock rods deburred and shot peened
rotating assembly balanced
Comp Cams 268H
Crane roller rockers
M1 dual plane
1" spacer
Speed Demon 650
Dynomax headers
2800 stall converter
727 reverse manual valve body
trans brake
This time next year I am hoping to have my 340 6-71 blown and injected engine finished and installed.
Link to my build thread. http://www.forabodiesonly.com/mopar/showthread.php?t=21167&highlight=START,FINSH
Here's a few pics.
Jack
67 Cuda Drag Car Built by Dave Young, Tech Editor of Mopar Muscle Magazine
440 stroked to 500 cu in - About 750 HP Engine Only
Indy heads & intake - Demon 1095 RS
MSD Ditgital 7 & Pro Cube
727 Trans Brake Reverse Valved
Dana 60 Spool 4:30
CAP Tubular Front end
CAL Trac bars & mono springs
Aero space disc brakes
10.5 x 28 Hoosiers
Runs mid to low 9"s in the quarter mile
