Mopar mopar forum
 HOME  FORUMS   MEMBER PHOTO GALLERY  CHAT    REGISTER  FABO STORE
 MEMBER CLASSIFIEDS  VIN DECODER  VIDEO GALLERY
Our Network:  B BODY MOPAR FORUM  C BODY MOPAR FORUM  E BODY MOPAR FORUM  FMJ BODY MOPAR FORUM  CAR AUDIO TALK  PICKUP TRUCK FORUM  FOR JEEPS ONLY
Go Back   For A Bodies Only Mopar Forum > Automotive Technical Forums > Electrical and Ignition
nuetral safety switch?
Thread Tools Search this Thread Display Modes
Old 01-12-2012, 09:56 PM   #1
440brew
440brew's Avatar
440brew's Flag is: United States
My dart will start in nuetral but not park. is this an issue with the nuetral safety switch?
440brew is offline   Reply With Quote
Old 01-12-2012, 11:03 PM   #2
67Dart273
67Dart273's Avatar
67Dart273's Flag is: United States
Most likely the linkage is out of adjustment, but it can be other things, bad switch, or bad/ bent "comb" inside the trans
67Dart273 is offline   Reply With Quote
Old 01-13-2012, 05:41 AM   #3
RedFish
Senior Member
RedFish's Avatar
Yep, When the steering column is lowered for some service while the shifter remains in park the linkage can get stretched out of adjustment. Just ne little bolt in the adjusting block to loosen and retighten will correct it but its under the car
RedFish is offline   Reply With Quote
Old 01-13-2012, 04:14 PM   #4
cudamark
cudamark's Avatar
cudamark's Flag is: United States
To test the switch, disconnect the shift linkage at the lever on the transmission. Slide the lever all the way to the rear. That should be park. See if it starts now. If not, there is a problem with the switch or components inside the transmission. If it starts now, the shift linkage needs adjusting.
cudamark is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Fabo Sponsors
Powered by: vBulletin Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Page generated in 3.14114 seconds with 17 queries
