**Twin Turbo 67 Dart Project**
Forced Induction Mopar
04-16-2012, 10:38 PM
#1326
dillingerchassis.com
It has been so long since I built mine, I can't remember. I just know when I ordered my bearing sets and rebuild kit I told them it was a big bearing for a bronco. Hmmm I must be getting old.
04-18-2012, 07:58 PM
#1327
On the Turbo Kool-Aid
Since I am changing to the 9" Ford Rear end, I figured I would change up the link set up and use Chromoly Heims this time with Chromolly Tubes. I bought all the pieces from A.R.T , the tubes have Chromoly weld in bungs. The tubes are long enough to cut to length. The lower tubes are 1 3/8's and the uppers are 1 1/4. Both are .095 Wall. The Heims are 3/4 thread with 1/2" Bolt Holes.
04-21-2012, 11:29 PM
#1328
04-21-2012, 11:37 PM
#1329
Get after it Louis.
04-21-2012, 11:42 PM
#1330
Quote:
Originally Posted by bremereric
Get after it Louis.
Yeah I'm trying. Just figuring out the Instant Center and where to mount and drill the brackets so I have plenty of adjustment took at least 5 Hours today. Alot of head scratching, measuring and re measuring was going on. It is over now. Just need to fab up all the brackets. After the Housing ends are on I will order the new 35 Spline axles, bearings and seals.
04-21-2012, 11:55 PM
#1331
Senior Member
Nice job bud..... finding center seems tricky on these b/c if the offset...
04-22-2012, 12:01 AM
#1332
That looks vaguely familiar. LOL
04-22-2012, 12:05 AM
#1333
Senior Member
I agree it does look familiar. lol
04-22-2012, 12:08 AM
#1334
I'm just trying to remember why I didn't weld in a cap and drain plug.
04-22-2012, 12:11 AM
#1335
Looks good John. I was going to do a 4 Link like that. I ended up calculating how low my car is going to sit and the upper front link bars were going to be up past the floor board into the car about 4" or so.
04-22-2012, 12:15 AM
#1336
Quote:
Yeah no more pumping that oil in there. It gets tiring. No more cracking the gasket on the 3rd member to drain the oil, removing the axles, dropping the 3rd member to replace the gasket. This is the Fat Mans easy way out.
The Oil fill doubles as an inspection hole also.
04-22-2012, 01:28 AM
#1337
Mr Horsepower
Why not just put Dana ends on the 9"? Use same brakes and axles? 35 splines axles are all the same aren't they?
04-22-2012, 05:38 AM
#1338
Quote:
The 8 3/4 had 30 splines.
04-22-2012, 01:15 PM
#1339
Real Mopar Guy
So how much money do you have into the motor again?
How much into the the whole project?
destined for Barret jackson later?
keep up the good work
04-22-2012, 02:45 PM
#1340
Thanks Justin!
Motor is about 10K with Everything, ECU, EFI, Intercoolers etc. Alot of what is spent here is my labor. Trans 2500.00, Rear end Swap $2000.00 with brakes. Swapping to the Ford 9" is going to be a wash except Labor.
I got about 20K in it so far if I am being honest and that includes the 2K I paid for the car. I probably got another 10-12K or so to finish it with Paint as long as I don't go in a different direction. I need to stick to the plan now. I was thinking to possibly
put a custom hood on it using the stock Cuda scoop inserts that are almost flat with the hood. I seen someone else do that and
it looks pretty cool.
I could pay someone to finish the car to speed up the process but I enjoy messing with it myself. It is a stress reliever for me. Hopefully I will be ready for paint before summer is over..... Knock on wood!!!
I won't be selling this one anytime soon.
04-23-2012, 05:17 AM
#1341
Anti-Socialist
Quote:
Originally Posted by Mad Dart
Thanks Justin!
LOL It's an awesome car. I see no incentive to sell it.
Keep crackin' at it!
05-03-2012, 10:15 PM
#1342
Well I have been receiving some parts lately. I got the Link Bars, Heims, Back Brace & 3rd Member.
I bought some chip board and made some templates of all my brackets so now those need to be transferred to the Chromoly Plate I bought and cut out.
My buddy Pete let me use his Housing End Tool Jig so I will be ready to put it all together once I get the brackets all cut out.
The 3rd Member has 3.50 Gears, 35 Spline Spool, Yukon Case, Daytona Big Bearing Pinion Support, Billet Steel 1350 Pinion Yoke with U Bolts. It should work out well. I painted it Satin Black with some Engine Paint I had laying around.
05-03-2012, 10:31 PM
#1343
That is purdy. What brand gear set did you go with? I think that I have a 9" 3.50 gear set in the garage from when I swapped out to 3.89's.
05-03-2012, 10:41 PM
#1344
Richmond Gears 8620 Heat Treated. The Spool is 4140 Heat Treated Moly that has the Scalloped Design.
05-03-2012, 10:42 PM
#1345
Nice piece!!!
05-03-2012, 10:47 PM
#1346
Nice piece and glad you went with the billet yoke and 1350 u-joints. I know about breaking yoke bolts and seeing sparks at night time.
05-03-2012, 10:50 PM
#1347
I hear that. I never understood the straps holding the U Joints. They seem to work but freak me out!
05-04-2012, 11:05 AM
#1348
Junior Member
Hey MadDart, I have question, I was just checking out your coilover converison and stock kmember, I was wondering, where did you get it, and do they make it for the b-body cars
05-04-2012, 11:11 AM
#1349
Junior Member
 I forgot to finish what I was going to say, I was checking your lower control arms, an was wondering wher you got them, an do they make it for B-body cars, they are really nice pieces an would look good on my RoadRunner, Thanks again
05-04-2012, 11:13 AM
#1350
Senior Member
I think the coilover is Baddart,a member here. He makes upper,lower control arms,j bar and rad support bars,lot's of stuff and it's all good! I have his jbars and rad support. Go a long ways towards stiffening up the front structure!
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
