Mopar mopar forum
 HOME  FORUMS   MEMBER PHOTO GALLERY  CHAT    REGISTER  FABO STORE
 MEMBER CLASSIFIEDS  VIN DECODER  VIDEO GALLERY
Our Network:  B BODY MOPAR FORUM  C BODY MOPAR FORUM  E BODY MOPAR FORUM  FMJ BODY MOPAR FORUM  CAR AUDIO TALK  PICKUP TRUCK FORUM  FOR JEEPS ONLY
Go Back   For A Bodies Only Mopar Forum > Automotive Technical Forums > Early A-Body Discussions
finally it looks like V-8 time
Thread Tools Search this Thread Display Modes
Old 11-28-2009, 12:29 AM   #101
37fleetwood
Senior Member
37fleetwood's Avatar
Ok, basically running again, I need to get a few things fine tuned. has anyone done the work for me on rejetting the AFB? I got a stock 1965 413 AFB and my Carter Strip Kit sitting here, has any one come up with a winning combination of metering rods and jets for a fairly mild 318 with stock exhaust? right now if I get into it I get a bit rich.
I'm also having a bit of trouble with the vacuum advance, with it hooked up I get surging and popping off idle when unhooked it runs great. I need to sort that out.
37fleetwood is offline   Reply With Quote
Old 02-17-2010, 11:18 PM   #102
37fleetwood
Senior Member
just realized I haven't updated this for a long time. the engine runs great the trans is working good now the exhaust is on and done the Barracuda had dual exhaust with glass packs so that's what's on it. I would have rather had a regular set of mufflers but it sounds good if a little loud. I have a pretty good amount of giddy-up-go considering the 2.76 gears. I have a 8 3/4" with 3.91 posi waiting for me to feel like tearing into it. I did a complete changeup on the wheels and tires, I moved from Rallies to steel wheels and 66 Charger Hubcaps and really like the look. I also went with a much bigger tire, 235/60/14 Uniroyal Tiger Paws. here is a photo or two of the car as it is right now:
Old 07-09-2012, 03:46 PM   #103
37fleetwood
Senior Member
well, after long and hard consideration, I have decided an upgrade was in order.
there are going to be two stages to the upgrade, the first is on it's way.
first, I have been looking into a cam and intake combination that will work better. the Offenhauser as it turns out is a real hamper to performance. they appear to do best when doing your recycling. So I went shopping on ebay and bought a slightly used Edelbrock Performer intake for $80.00. it looked best overall in a Hotrod Magazine test I read.
the other thing is the Crane cam. after flattening a lifter or two,and not as hot as expected performance, I've decided to go a different way, so I went hunting and came up with a Hughes Whiplash cam. I called and talked to their tech guy and he told me the down side to these cams are in the 6000rpm range, and that I probably wouldn't, or shouldn't run into that problem. he assures me that it should make gobs of low end torque, and work and sound great with my setup.
I'm contemplating a head swap while I'm at it. also contemplating a move to manual steering in a forward look towards a future with headers, or Dakota exhaust.
the next stage is a planned move to a THM-200-4R overdrive trans, and 8 3/4 3.91:1 rear axle setup. all indications are that the trans is strong enough to hold my horsepower, and small enough to install without cutting into the floor board. the issues are fabricating mounts, linkage, and dealing with the lock-up converter, none of which should be that hard to overcome.
I'm planning a new video of it running soon!
Old 07-11-2012, 08:52 PM   #104
moparlee
64 Valiant
moparlee's Avatar
moparlee's Flag is: United States
Your car looks good. I like the hub caps.
moparlee is offline   Reply With Quote
Old 07-12-2012, 03:44 PM   #105
Thumpower
Junior Member
Thumpower's Avatar
Thumpower's Flag is: United States
Your 64 looks hauntingly like my old one I had many years ago...Could the original plate have started with ORJ?
Thumpower is offline   Reply With Quote
Old 07-12-2012, 10:44 PM   #106
37fleetwood
Senior Member
mine came from the proverbial little old lady from Pasadena. apparently she was a teacher at Pasadena College as it had a parking pass. she must have got too old to drive and ran it into something in the driver fender and it ended up in a wrecking yard up here in the Antelope Valley.
all the boxes have now arrived so maybe this weekend I'll get everything changed.
Old 05-05-2013, 01:52 PM   #107
braptor52
braptor52's Avatar
braptor52's Flag is: United States
any updates on the car? was reading through this thread and am really liking what you have done so far
braptor52 is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Similar Threads
Thread Thread Starter Forum Replies Last Post
Finally took time to work on the Duster J-MacsMopars General Discussion 3 07-24-2009 09:26 PM
long time watcher-first time poster william grayson Welcome Wagon 25 04-28-2009 01:51 PM
Long time reader first time poster bob shaner Welcome Wagon 11 12-31-2008 11:20 PM
Track time for the Dart, finally!!! HAMMERTIME Racers Forum 17 04-24-2007 07:50 PM
FINALLY, out of the garage for the first time with color rcottick Mopar General Discussions 21 10-18-2005 11:32 AM
Fabo Sponsors
Powered by: vBulletin Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Page generated in 0.17480 seconds with 22 queries
