Small block valve covers for sale
70DartMike
Too many projects
Vancouver Island, Canada
I've got 2 pairs of small block M/T valve covers for sale. They fit 318/340/360. Both pairs will need to be cleaned up/blasted, but they're in good shape. No grommets.
$50 each.
I also have numerous pairs of stock 318 valve covers.
$20 each.
Also have /6 valve covers.
$20 each.
Parts are located in Parksville, BC, Canada.
Prices may be negotiable.
will they fit magnum heads? yes im a small block noob
Yes. But you need to run some really GOOD valve cover gaskets or they'll leak. The MP steel core rubber reusable ones are good. Expensive, but the last V/C gaskets you'll ever need to buy. I have an old set of aluminum covers on Frankenteen. They fit good.
Not sure, I have a set of cork gaskets on my X heads and they leaked a bit, but they've stopped now. I used them because the stock 318/360's wouldn't clear my rockers.
i dont understand... are what is different that causes them to leak without good gaskets?
might be interested in the steel stamped ones. But they dont look like 1970 blue was 72 and on. Please inform or send better pics.
