Mopar mopar forum
 HOME  FORUMS   FABO STORE   MEMBER PHOTO GALLERY  CHAT  MEMBER CLASSIFIEDS  MOPAR VIN DECODER   REGISTER
 VIDEO GALLERY  NEW POSTS  TODAYS POSTS  SEARCH  CALENDAR  B BODY MOPAR FORUM  E BODY MOPAR FORUM
Go Back   For A Bodies Only Mopar Forum > Automotive Technical Forums > Fuel and Air Systems
NON-EGR INTAKE MANIFOLD on EGR ENGINE
Thread Tools Display Modes
Old 02-07-2010, 10:43 PM   #1
Ghostsoldier
Junior Member
Ghostsoldier's Avatar
Guys,
I've got a opportunity to pick up a Edelbrock non-EGR #2176 intake for cheap, but my son's '74 Duster has an '86 EGR 318 engine swap on-board...I'm not educated enough in small-block wisdom (yet---I'm learning) to know if I could use the non-EGR intake on his engine, but I'd hate to lose the deal, if I could possibly use it.
We have removed and/or disconnected all the emission parts from the original '86 system (as well as all the lean-burn crapola--we swapped out the distributor), and have installed a new Edelbrock #1406 600 cfm non-EGR 4-barrel carb on the stock cast iron manifold (we are having to use an adapter plate, though)....it runs really well at this time (The reason we are having to change out the stock cast manifold, is because the water temp sending unit hole has split across the top of the manifold, and is leaking like crazy--long story).
I was thinking it would be a matter of using a different intake gasket set for installation of the non-EGR manifold, or a block-off plate of some type, but I'm not sure if it would leave that small center intake passage in the head, open for leaks.
Can I use it?
Rob
Ghostsoldier is offline   Reply With Quote
Old 02-07-2010, 10:59 PM   #2
grumpuscreature
Resident Curmudgeon
grumpuscreature's Avatar
grumpuscreature's Flag is: Guam
Buy it. The only difference is the non EGR manifold is not machined for an EGR valve. Both manifolds have the crossover passage for intake heat so you will use the same intake gaskets for either manifold.
grumpuscreature is offline   Reply With Quote
Old 02-07-2010, 11:17 PM   #3
169dart4y
Senior Member
169dart4y's Avatar
169dart4y's Flag is: United States
Thumbs up egr valve
Don't meen to steel your post but I have a eldabrock preformer intake with a egr valve installed on a 74 318. I bought the car and put the 318 in my 69 ,don't need the egr . Can I just remove it and do they make a plate to block it off? I just capped the one line off it. Thanks
169dart4y is offline   Reply With Quote
Old 02-08-2010, 01:06 AM   #4
rumblefish360
Dynamic duo at the ready!
rumblefish360's Avatar
rumblefish360's Flag is: United States
No block off plates are made. You can make one yourself with the gasket (New one should be used) as a template for a 1/4 steel plate. Thicker the better for this plate since it see extreme exhaust heat.
The Cheapest way is to remove the hose and plug the carb port or hose. LEave the EGR valve alone. A uncaped EGR valve is not a big deal at all.
rumblefish360 is offline   Reply With Quote
Old 02-08-2010, 11:47 AM   #5
Ghostsoldier
Junior Member
Thanks, guys....I'll pick it up!
Rob
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
64 intake manifold Valiant63 Early A-Body Discussions 18 05-27-2009 03:55 PM
Cross Ram Intake Manifold for LA series engine? race66 Small Block Tech 11 06-26-2008 03:41 AM
Intake Manifold abodybill Cars and Car Parts Wanted 4 04-14-2008 05:44 PM
340 Intake Manifold Darius Small Block Tech 10 06-10-2007 09:43 AM
Which Intake Manifold? 7duster4 Mopar Performance Issues 5 11-27-2006 12:57 AM
FABO SPONSORS
Limited Edition FABO T-Shirt
Mopar T Shirt
LAST CHANCE! Get Yours Today!
Dales Cuda Shop
Rosevilla Mopar Parts
Charger Specialties
Performance Suspension Technology
Inertia Motorsports
1960-1976 Plymouth Valiant - 1963-1976 Dodge Dart - 1964-1969 Plymouth Barracuda - 1971-1976 Plymouth Scamp
1970-1976 Plymouth Duster - 1961-1962 Dodge Lancer - 1971-1972 Dodge Demon - 1971-1981 Valiant Charger (Australia Only)
air suspension | suspension parts
Powered by: vBulletin Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Page generated in 0.13919 seconds with 13 queries
