Mopar mopar forum
 HOME  FORUMS   FABO STORE   MEMBER PHOTO GALLERY  CHAT  MEMBER CLASSIFIEDS  MOPAR VIN DECODER   REGISTER
 VIDEO GALLERY  NEW POSTS  TODAYS POSTS  SEARCH  CALENDAR  B BODY MOPAR FORUM  E BODY MOPAR FORUM
Go Back   For A Bodies Only Mopar Forum > Automotive Technical Forums > Small Block Tech
building a 360
Small Block Tech
Thread Tools Display Modes
Old 02-26-2010, 11:38 PM   #61
fishy68
Tyr Fryr's Inc.
fishy68's Avatar
fishy68's Flag is: United States
Quote:
Originally Posted by mynumber38 View Post
Hey fishy just a quick question.I had the block bored 40 over.The cylinder measures 4.037 and the gasket measures 4.145 with a thickness of .055 will this gaskett compress to 4.040 or should I buy new gasketts.I am not really worried to much about the thickness,just dont want the gaskett to cover and of the cylinder by compressing to far.Thanks,Eddie
You'll be fine. I have never measured how much it compresses inward but I'm sure it's nowhere near that much.
BTW: Are you sure about the finished bore diameter? I'm not a machinist but I think the bore diameter should be 4.04 for a .040 over. The piston diameter is less to allow for clearance. If their forged pistons 4.036~4.037 is in the ballpark for what they should measure. Somebody please correct me if I'm wrong on this as I don't want to give bad information.
fishy68 is offline   Reply With Quote
Old 02-27-2010, 09:27 AM   #62
mynumber38
mynumber38's Avatar
I did use a caliper/micrometer to measure the cylinders and that is what I came up with.Now the caliper could be wrong,after all I did buy it at a harbor freight discount tool store.As for the pistons they were speedpro .040 flat tops with valve rieliefs.I dont think they are forged because they only cost me 250. and some change.I dont know much about forged or not forged.They could be a forged piston.Thanks for the info!
mynumber38 is offline   Reply With Quote
Old 02-27-2010, 09:52 AM   #63
octanejunkie
Mopar Padawan
octanejunkie's Avatar
I would hazard a guess that the OP's measurement on the bore is off, .003" ain't that much to fudge with a regular caliper, regardless of it's source, you really need an inside mic or bore gauge
If there are concerns regarding the bore diameters or boring of the block I would contact the machinist/shop that did the work and ask what their tolerance is and whether they have any records of bore concentricity prior to their work, both parallel and perpendicular to the crank bore if possible
If you do call the shop I would also inquire into deck height, whether they took any measurements off the crank center line to the deck surface. Once you mock-up the build and measure piston-to-deck clearance you may want to mill the decks to square up your deck surfaces and set/tune your deck clearance, compression and quench.
octanejunkie is offline   Reply With Quote
Old 02-27-2010, 10:26 AM   #64
1wild&crazyguy
Disconnected
1wild&crazyguy's Avatar
1wild&crazyguy's Flag is: United States
Good ideas guys.
I would think a stock piston bottom end, given it's new, with .045 milled off the heads [of corse whats the current cc?] and .040 off the intake side, if you have to ..use the thin magnum intake gasket, 1 Step above a stock 340 cam like .468/268* or XE268*, rpm/ld340 dual plane intake, 650-700cfm carb, and headers would make 325-350hp
1wild&crazyguy is offline   Reply With Quote
Old 02-27-2010, 05:16 PM   #65
mynumber38
mynumber38's Avatar
I am running speedpro .040 flat tops with valve rieliefs,280 474 purple cam-360 heads with 188 160 valves heads were milled 20, torker or air gap intake with 670 holley havent decided yet.I have installed clevite rod and main bearings.Also going to run headers,hoping to make 330 to 350 hp.The piston with number one up is real close to being flush with the top of the cylinder.What do you think of this combination,can I achieve my goal.Thanks,Eddie.
Old 02-28-2010, 11:45 AM   #66
octanejunkie
Mopar Padawan
If you have the slugs in the holes you can measure your deck height (piston-to-deck clearance) and use the CR calc at kb-silvolite.com to calculate/estimate your CR - of course you will need to CC the combustion chambers of your heads and choose a gasket to work with as well as know the piston volume
All minor details add up, sometime considerably
Old 02-28-2010, 01:35 PM   #67
mynumber38
mynumber38's Avatar
Anyone know if the airgap intake with mopar breather will fit under the hood of the 70 Duster Im building.I want to run this intake but I dont want to buy it if it wont fit.
Old 03-01-2010, 08:07 PM   #68
mynumber38
mynumber38's Avatar
I have a quick question,I installed my stock rockers today and it seems they are putting the push rods in a bind.They are stamped 31 rt 32 rt 32 Lt 33Lt I dont uderstand what this is.I know there seems to be a left and right.Is there something I am over looking,do you know of a web site I can check out.I seem to have them on right know but it seems like the rocker is not sitting center on the valve.If you need a picture of this send me your email and I will send you a pic,that is if you dont mind helping me out.Thanks,Eddie
Old 03-01-2010, 08:45 PM   #69
fishy68
Tyr Fryr's Inc.
fishy68's Avatar
Your correct that there is left and right and if not in the right place they won't be centered on the valves. I wish I had a pic to post but I don't. There pretty easy to decipher which way they go if you look at them. Move them around until you get them in alignment. As far as the numbers I have never noticed numbers stamped on them but in honesty I have never looked very close.
Old 03-02-2010, 07:45 PM   #70
mynumber38
mynumber38's Avatar
I will take them back off and move them around untill they seem to fit.They are on there now but dont seem to be center on the valve.Thanks,Eddie
Old 03-02-2010, 07:57 PM   #71
fishy68
Tyr Fryr's Inc.
fishy68's Avatar
That's what I did the first time I did one. You'll get it.
Old 03-06-2010, 08:59 AM   #72
mynumber38
mynumber38's Avatar
Thumbs up
Yeah it was pretty easy once I got into it.I marked the ones that were right on one side and the ones that were wrong on the other side and switched them and that was the fix.Thanks again.
Old 03-08-2010, 11:22 PM   #73
spstacman
spstacman's Avatar
spstacman's Flag is: United States
so i am working on getting all the pieces together for a 360 build i think i am going to run kb107 pistons do i have to worry about the valves clearing the piston
spstacman is offline   Reply With Quote
Old 03-09-2010, 10:10 AM   #74
octanejunkie
Mopar Padawan
Quote:
That depends on many things, namely how much lift cam are you planning on running, what heads you are running and whether the pistons pop out of the bores, among other variables...
Old 03-09-2010, 10:48 AM   #75
360moparjunkie
Senior Member
I think you can use clay to measure your clearance to valve during construction. You are not there yet imo.
Start a new thread with all your piston clearance questions as well as any others.
You will have 100x the exposure to the questions will have. Members have to stumble onto your questions this way. Just trying to help you out.
360moparjunkie is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Something different Building for MPG. AdamR Mopar Performance Issues 76 12-04-2008 10:49 AM
WI new guy building a 70 swinger Boxer Welcome Wagon 13 12-30-2007 12:49 AM
building the 904 DusterBoy15 Transmission and Drivetrain Tech 1 07-12-2007 08:36 PM
Building a 360 Joseph24251_200 Small Block Tech 2 12-29-2006 01:44 PM
need help building up a 318 greaserkid Mopar Performance Issues 10 10-25-2005 08:36 AM
FABO SPONSORS
Limited Edition FABO T-Shirt
Mopar T Shirt
LAST CHANCE! Get Yours Today!
Dales Cuda Shop
Rosevilla Mopar Parts
Charger Specialties
Performance Suspension Technology
Inertia Motorsports
1960-1976 Plymouth Valiant - 1963-1976 Dodge Dart - 1964-1969 Plymouth Barracuda - 1971-1976 Plymouth Scamp
1970-1976 Plymouth Duster - 1961-1962 Dodge Lancer - 1971-1972 Dodge Demon - 1971-1981 Valiant Charger (Australia Only)
air suspension | suspension parts
Powered by: vBulletin Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Page generated in 0.25493 seconds with 13 queries
