Mopar mopar forum
 HOME  FORUMS   MEMBER PHOTO GALLERY  CHAT    REGISTER  FABO STORE
 MEMBER CLASSIFIEDS  VIN DECODER  VIDEO GALLERY
Our Network:  B BODY MOPAR FORUM  C BODY MOPAR FORUM  E BODY MOPAR FORUM  FMJ BODY MOPAR FORUM  CAR AUDIO TALK  PICKUP TRUCK FORUM  FOR JEEPS ONLY
Go Back   For A Bodies Only Mopar Forum > Automotive Technical Forums > Electrical and Ignition
What have I done - A side blinker story
Thread Tools Search this Thread Display Modes
Old 08-29-2012, 03:13 PM   #1
Lari Cheltsy
Grasshopper
Lari Cheltsy's Flag is: United States
Well I've always wished that the side indicators on my '73 Valiant could blink for safety reasons in town and thanks to
http://danielsternlighting.com/tech/...rkerflash.html
I was able to make just that happen cheaply, quickly, and easily.
BUT NOW
When my parking lights or head lights are one, so are the turn indicators in the instrument cluster speedometer. Not blinking, but steady.
What can I do to either remedy this, or to just do away with the cluster indicators? Because if it comes down to it, I'd feel better/safer with blinking side lamps than having working indicators.
Lari Cheltsy is offline   Reply With Quote
Old 08-29-2012, 04:05 PM   #2
mcnoople
Senior Member
mcnoople's Flag is: United States
Does everything else work as it should? How fast do the turn signals flash: Fast, slow, normal? Are all bulbs properly bright?
Stuff like this usually happens from a poor ground and the current has to find a path back to ground wherever it can.
mcnoople is offline   Reply With Quote
Old 08-29-2012, 04:12 PM   #3
TrailBeast
Slightly Twisted Member
TrailBeast's Avatar
TrailBeast's Flag is: United States
It's a bad ground like stated above.
TrailBeast is online now   Reply With Quote
Old 08-29-2012, 04:12 PM   #4
Lari Cheltsy
Grasshopper
Everything seems to be working as normal. Blinking is a bright and rhythmic as always.
Old 08-29-2012, 04:45 PM   #5
mcnoople
Senior Member
Two approaches come to mind
1. measure voltage drops and circuit resistances on each individual leg of the running light circuit.
2. pull 1 bulb at a time until the indicator is no longer lit up. This is the method I would try first. The power that is lighting up the indicator has to be coming from somewhere and this method is interrupting circuits that might be supplying the power.
Your suspect bulbs are dash lights, taillamps, front running lamps. Does turning the dimmer switch have any effect on the turn indicator?
Old 08-29-2012, 05:21 PM   #6
67Dart273
67Dart273's Avatar
67Dart273's Flag is: United States
It's -- a -- ground -- problem
Up front
67Dart273 is online now   Reply With Quote
Old 08-29-2012, 06:49 PM   #7
TrailBeast
TrailBeast's Avatar
Like park/signals up front probably.
Old 08-29-2012, 07:42 PM   #8
briankaplan
greenduster
briankaplan's Avatar
briankaplan's Flag is: United States
If you are running the turn signal power and the running lites power both
to the side markers. You need a one way diode in line. Kind of like the boxes
for the old trailer lights. to run the turn signals and the brake lites together.
Not to sure how you should set it up though.
Just my 2 cents worth. Not a ground problem.
briankaplan is online now   Reply With Quote
Old 08-29-2012, 08:21 PM   #9
RedFish
Senior Member
RedFish's Avatar
It's been a very long time since I messed with this lighting setup.
If I'm not mistaken you have to reroute the factory ground path so the only path is through the little marker lamp bulb.
Not so easy to try if you have chassis grounded metal fixtures such as your fender top fixtures.
RedFish is offline   Reply With Quote
Old 08-29-2012, 08:36 PM   #10
67Dart273
67Dart273's Avatar
This stuff can REALLY throw ya. When I was in the navy, several friends had mid 60's chivvies, which have part of the lamps mounted on the trunk LID. These cars were a nightmare to keep the lights working, until you solder grounds to the lamp shells, and run a flex ground wire from the trunk lid to the body.
Old 08-29-2012, 08:45 PM   #11
RedFish
Senior Member
RedFish's Avatar
Quote:
Yep, the GM products are a little different in some places and a lot different in others. Their blinking side markers or cornering lamps were wired similar to what \6Dan suggests. 89 Cutlass comes to mind as a example but my memory has failed me.
Reply
Search this Thread:
Advanced Search
Display Modes
Similar Threads
Thread Thread Starter Forum Replies Last Post
Sounds like my blinker is on but is not. MoparMuscleGuy Electrical and Ignition 4 04-26-2012 11:24 AM
blinker switch bill detamore Electrical and Ignition 9 11-05-2010 05:25 PM
blinker switch location iggys68dart Electrical and Ignition 2 11-04-2010 02:38 PM
Parts Store Rant, the other side of the story dusterglenn Mopar General Discussions 58 01-15-2010 04:52 AM
Fabo Sponsors
Powered by: vBulletin Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Page generated in 0.19835 seconds with 25 queries
