Mopar mopar forum
 HOME  FORUMS   MEMBER PHOTO GALLERY  CHAT    REGISTER  FABO STORE
 MEMBER CLASSIFIEDS  VIN DECODER  VIDEO GALLERY
Our Network:  B BODY MOPAR FORUM  C BODY MOPAR FORUM  E BODY MOPAR FORUM  FMJ BODY MOPAR FORUM  PICKUP TRUCK FORUM  FOR JEEPS ONLY
Go Back   For A Bodies Only Mopar Forum > Automotive Technical Forums > Transmission and Drivetrain Tech
Trans. cooler question
Thread Tools Search this Thread Display Modes
Old 08-10-2012, 04:13 PM   #1
Darwin
Evolutionary Member
Darwin's Avatar
I'm installing an external cooler to my automatic transmission, which cooler line runs to the cooler, and which line returns to trans. I believe if I run the hot fluid to the top of the cooler and let gravity do its thing, it will be much easier on the trans.
Thanks, Bob
Darwin is offline   Reply With Quote
Old 08-10-2012, 04:28 PM   #2
mopardude318
Senior Member
mopardude318's Avatar
..............in this thread you can see how i did mine....it might help ya................
http://www.forabodiesonly.com/mopar/...d.php?t=146504
mopardude318 is offline   Reply With Quote
Old 08-10-2012, 04:36 PM   #3
Bad Sport
HALF A BUBBLE OFF
Bad Sport's Avatar
Bad Sport's Flag is: United States
The front line is the one from the pump. I left that alone on mine going into the tank. I used the one coming out of the tank into the cooler then from the cooler to the return line.
Bad Sport is offline   Reply With Quote
Old 08-12-2012, 02:04 AM   #4
BillGrissom
Cheap Mopar Bastard
BillGrissom's Avatar
BillGrissom's Flag is: United States
Gravity doesn't matter. Since the outlet (front) and return (rear) of the transmission are at the same height, there is no pressure change from the up and down. That is why a siphon hose works.
It doesn't matter which way you flow thru the cooler, at least for the ones I have seen. Actually, there is a slight theoretical advantage in going it at the top and returning at the bottom, if your cooler has horizontal tubes. That is because the air is slightly warmer at the top. It is a heat transfer effect and has nothing to do with fluid pressure (or height). Lookup "cross-flow heat exchanger", but surely doesn't matter here.
A bigger question is whether you want to keep your radiator tranny cooler in series. That helps a little, but has the disadvantage of risking oil in the coolant or (worse) water in the tranny. I decided not to. If you do, probably best to run thru the radiator cooler first. As I read, there is no risk of over-cooling the tranny fluid unless you live above the Arctic Circle.
BillGrissom is offline   Reply With Quote
Old 08-12-2012, 02:27 AM   #5
autoxcuda
Senior Member
autoxcuda's Avatar
I'm pretty sure my trans cooler is also a Tru-Cool M7B or same part different reseller.
NS1RM21 (Troy) ran the cooler lines down the frame rails to get them away from the motor.
autoxcuda is online now   Reply With Quote
Old 08-12-2012, 11:10 AM   #6
Darwin
Evolutionary Member
Darwin's Avatar
Thanks guys for the input.
The radiator I put in has no trans cooler in it so no need to run in series.
I finished it up yesterday, heres how it turned out
Old 08-12-2012, 11:37 AM   #7
mopardude318
Senior Member
nice man!
Reply
Search this Thread:
Advanced Search
Display Modes
Similar Threads
Thread Thread Starter Forum Replies Last Post
Trans cooler as oil cooler? player1up Forced Induction Mopar 5 10-25-2010 09:24 PM
Trans cooler or not? Badart Transmission and Drivetrain Tech 8 08-16-2009 07:00 AM
Do i need a trans cooler? n00blike Transmission and Drivetrain Tech 7 07-07-2009 09:25 PM
trans cooler sizing question? 71swing Transmission and Drivetrain Tech 5 04-05-2007 11:37 PM
Trans cooler question Jmac81d Heating / Cooling / AC 4 10-10-2005 04:38 PM
Fabo Sponsors
Powered by: vBulletin Version 3.8.8 Beta 1
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Page generated in 0.15966 seconds with 22 queries
