9.5" 4 spd flywheel/bellhousing/pedal assy
DartmanTampabay
St. Petersburg, FL
  • 10.5” 130 tooth, 26 lb flywheel – internal balance for 318/340 (needs to be turned), all threads tapped - $65 ea
  • 1963-66 A-body Clutch/brake pedal assembly (missing the spring) - $75
  • 9.5” 122 tooth, 18 lb flywheel (needs to be turned), all threads tapped - $35 ea
  • Cast Iron SB Bell housing, all threads tapped, casting # 2806081 (for smaller 9.5 flywheel) 67-69 273 - $65
Prices OBO and will package deal 3 together
Prices do not include shipping - from zip 33708
Consider partial trades on 1967-72 4 A-body 4 spd shifter rods & levers.
Thanks
