upper control arms
inkjunkie
Bushings or rod ends? Car will be a street/strip deal. Will have a 2nd Generation Hemi in it, so handling is of little or no concern. Other than the adjustability of the rod ends, is there any advantage? Firm Feel? RMS? ????
I thought it was
Rod end style for best performance on the street or track.
Bushing Style- recommended for best performance on Street/handling.
I know Bill recommend Rod ends for my Drag/Street car
If it going to be a straight line type car with big 426 type engine, skinny tires and not concerned with handling... just run stock UCA's with moog offset bushing installed for more caster.
Whoa, wait a second... offset bushings? Where do I find these? I looked at all moog bushings on summit and nothing about them was to be found.
Yep, you get them at rockauto.com
Moog PN: K7103 $27.79 for 2 bushings (1 side)
So about 60 bucks for offset bushings...
Install them per these instructions for more caster. NOT the instructions that come in the box/kit.
Is this the only way to get caster w/ the "fixer" bushings? I installed mine as suggested on the box. Should I be able to get positive caster from this?
You probably can gain some caster adjustment. But not as nearly as much as if they were installed per those instructions.
