res1vw21
It's only metal
Well I am just testing the waters on with this one, I still haven't decided yet it I want to sell my dart but I keep thinking about it...
Here is the build thread so you can see what all I have done to her.
http://www.forabodiesonly.com/mopar/showthread.php?t=34453
I have poured my heart and sole into this fine ride, it's a lot of fun to drive but I keep finding myself thinking about my '52 wagon and how fun it will be to chop channel and do in a full custom.
The specs.
The car:
It is still a bit of a project but I have been driving it and loving it
It still needs a front end alignment (ruff aligned for driving) the interior needs to be finished. The Rallys that are on it do not come with it but I do have a set that have been blasted and painted with caps and centers, for an extra $400.
I know I am forgetting some things, feel free to ask Questions
Car is located near Seattle WA
I am asking $13,500
I am still not sure that I want to sell and I don't have to sell so...
The specs.
The car:
- Spool mount V8 K member
- Rebuilt front suspension
- New Firm Feel stage 2 PS box
- 340 t bars
- LBP Disks All rebuilt with new pads and rebuilt caliper, with new soft lines and adjustable rear proportioning valve
- Line lock
- Factory front sway bar
- LBP B body 8 3/4 with rebuilt 742 clutch pack sure grip, new 3.55 gears, new mosser axles with green bearings and new brakes
- New SS #2800lbs springs
- New KYB gas adjust all the way around
- Custom Rally Dash with all rebuilt gauges, 150 mph spedo and new repo tach and plastic glove box
- New pioneer Stereo head unit with Ipod hook up
- Floor shift steering column with new repo tuff wheel
- proper '70- early '71 bucket seats
- new headliner, new dome light lens
- Newer black carpet
- Decent door panels
- Fresh paint Toungston blue metallic
- I have new vertical stripes for the butt stripe
- There is one little spot of rust coming through on the drivers 1/4 wheel lip, easy fix I just haven't done it yet
- New hood scoop bezels on a set of original 340 scoops
- Reproduction Hood pin set
- Freshly painted grill
- New radiator
- New bearings and rings
- Turned crank
- New 360 flywheel and clutch
- rebuilt '76 360 heads
- custom ground delta cam (I have the specks just have to find them)
- Hooker Headers
- Performer intake
- Carter 600 cfm carb
- Mopar performance Valve covers
- orange box ignition
- double roller timing chain
- K&N Air filter
- 4spd OD with Hurst shifter
- New summit 2.5 exhaust with H pipe
- Rebalanced factory drive shaft for A833 and 8 3/4 with new yoke and u joints
I am asking $13,500
