parting out my 4-speed Duster, lots of parts!
SublimeDusterSK
Political Dissident
Roseburg OR State of Jefferson
Rating - 0%
0   0   0
OK i am parting out my Duster. i am doing 5MGTE engine swap and will not be needing any of the listed items from my car.....
A-body radiator V8 $50
non ac pulleys and brackets $50
15x7 and 15x8 rally wheels with tires $600
http://i228.photobucket.com/albums/ee315/jennkloster/myspaceduster010.jpg
http://i228.photobucket.com/albums/ee315/jennkloster/myspaceduster019.jpg
v8 electronic ignition dist. and orange box $100
360 fresh short block dated 2-1970!! "Price to be determined" 10.8:1 with 70cc head 13.2:1 with 63cc head
stock flywheel for 318 with strong clutch $100
1984 318 short block, good lower end. ran great before tore down. now needs rings and gaskets $100
SEMA approved steel flywheel for 360 $200
New 8 pad racing clutch and cover 10.5 in. kit $150
A-833 trans and bell housing for A-body all cast iron O.D. box. great working when pulled. i also have a spare trans for parts. $1000 all transmissions & parts
A-body shifter boot and trim ring "to be sold with trans"
A-body clutch linkage and bell crank with heim joints "to be sold with the trans"
Shifter complete with rods A-body "to be sold with trans"
3310 750 holley carb $100
340 intake stock cast iron. early 340 68-69 $150
1974 360 J heads hardened seats good springs and retainers $250
340 exhaust manifolds 68-69 $400
A-body exhaust tips, exhaust system with dual Flowmaster 2 chambers.
http://i228.photobucket.com/albums/ee315/jennkloster/1012101711.jpg
http://i228.photobucket.com/albums/ee315/jennkloster/1012101740.jpg
http://i228.photobucket.com/albums/ee315/jennkloster/1012101727.jpg
http://i228.photobucket.com/albums/ee315/jennkloster/1012101635.jpg
if you are looking for any of these parts for your car, contact Steve before 7pm at (nine five one) three zero six - two seven zero eight.
id be interested in your flywheel..im in need of a 360 fw....what condition...can you send pics or is it still in the car...
you got the linkage arms for a 833 OD trans
this was a running car before pulled apart. the only parts that i am keeping from 4spd set up are the pedals only. i have the shifter, rods, chrome trim ring, shifter boot, two O.D. transmissions "note the spare one is a long shaft trans", small block bell housing, i have a steel 360 flywheel, 318-340 flywheel, the clutch bell crank and clutch rods have been fitted with Heim joints instead of the metal to metal stock set up, fenderwell and bell housing pivot balls.
all the parts that i have left are.......
340 exhaust manifolds "have sale pending" $400
360 steel flywheel. $150
360 block dated 2-1970 the bore is .060 and has rust spots. needs sonic check to determine safe to over bore more. these early blocks are known for thick cyl walls.
make offer my feelings will not be hurt!
new .060 KB190 pistons on re sized rods $150
i have a used purple shaft cam .490 - 276 dur. solid lifters, push rods and adjustable rocker arms $150
cast 360 crank, polished with new with bearings $100
would you be able to cut the floor hump out of it? id be interested in that
Hello
I am looking for a 360 car oil pan. Rear sump (Original chrysler. This is for a 1974 plymouth duster. Not 1 of the crome after markets oil pans. I already have 1 and they leak.
Please quote price and shipping.
Thank You
L samuels
I am interested in the 318 flywheel if still available. ooops read again looks like it gone!
