Mopar mopar forum
 HOME  FORUMS   MEMBER PHOTO GALLERY  CHAT    REGISTER  FABO STORE
 MEMBER CLASSIFIEDS  VIN DECODER  VIDEO GALLERY
Our Network:  B BODY MOPAR FORUM  C BODY MOPAR FORUM  E BODY MOPAR FORUM  FMJ BODY MOPAR FORUM  CAR AUDIO TALK  PICKUP TRUCK FORUM  FOR JEEPS ONLY
Go Back   For A Bodies Only Mopar Forum > Automotive Technical Forums > Mopar Performance Issues
Post your combo
Thread Tools Search this Thread Display Modes
Old 08-11-2012, 12:00 AM   #126
bad440
everything,all the time..
bad440's Avatar
bad440's Flag is: United States
Quote:
Originally Posted by 70aarcuda View Post
Car 71 Dodge Dart Swinger
Weight 2875
Gear ratio 4.56
Tire diameter 29
RPM through trap 6500
MPH through traps 121.58
ET 10.911
Engine CID 360 +.060
Head Type eddy
Valve size 2.02/1.60
Head Work cnc hughes
Cam Manufacturer hughes
Cam specs at 50 260/264
Carb type and size 950 holley
PV Rating 3.5
Jet sizes 74/82
Plug number and brand ngk
Intake Manifold Type Weiand X-celerator
Piston Make Wiseco (MP)
Compression Ratio 11 to 1
Trans type 904
Trans Mods 5 disc..& mulitspring kit front clutch pac
Convertor type Turbo Action
Convertor stall 5000
Trans Brake Tranzact of Indy
Drive shaft stock or aftermarket Stock with 7260 u joints
Initial timing
Total timing 34
Total advance at what RPM 1500
thats a well thought out combo....
bad440 is online now   Reply With Quote
Old 08-11-2012, 12:18 AM   #127
perfacar
Senior Member
perfacar's Flag is: United States
re
1972 duster 340 , hyd stockercam, stock intake and thermo Quad, 1.88 & 1.60 valves, 8.5 C.R. ross pistons, stock stroke crank, jerico trans, mcloed flywheel and clutch, dana 60, 5.57 gears, 9x 30 slicks, 3350 #, 11.37 @ 116 + mph
perfacar is offline   Reply With Quote
Old 08-11-2012, 10:12 PM   #128
SBDart
Senior Member
SBDart's Avatar
SBDart's Flag is: United States
Car 71 Dart AKA Augie
Weight?? 3400
Gear ratio 4.30
Tire diameter 255xR60x 15's
RPM through trap?
MPH through traps?
ET Hope 11.80's ?????????
Engine CID 416 storker
Head Type RHS / Indy X's
Valve size 1.92 /1.60
Head Work very little
Cam Manufacturer Lunati
Cam specs at 50 242 in / 252 ex
Carb type and size Bigs 750 stage 5 Holley 4150 hp
PV Rating 4.5
Jet sizes 75 primary 82 secondary
Plug number and brand N/A
Intake Manifold Type Super Victor
Piston Make scat ?????
Compression Ratio 9.7.1
Trans type 904
Trans Mods none N/A
Convertor type N/A
Convertor stall N/A
Trans Brake None
Drive shaft stock or aftermarket N/A
Initial timing N/A
Total timing N/A N/A
Total advance at what RPM N/A
Rear end type Dana 60
SBDart is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Similar Threads
Thread Thread Starter Forum Replies Last Post
How do I post photos Joeychgo Website Help / Suggestions 206 04-01-2013 10:27 AM
whats the deal with a 2dr post GT_My_way General Discussion 18 03-24-2006 02:57 PM
I Lost a post somewhere gts340 General Discussion 14 03-31-2005 06:51 PM
My New Combo TC67CUDA General Discussion 13 01-20-2005 10:18 PM
Post search Sparky General Discussion 3 11-22-2004 11:41 AM
Fabo Sponsors
Powered by: vBulletin Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Page generated in 0.15244 seconds with 17 queries
