what is this?
1969dodgedartgt
CA
the thing on the left with the wire coming out.
whats it suppose to do? doesnt look like it has any lens for a light
thanks
thats the gyromagic adjuster it opens a portal to another dimension where naked ladies drive chargers and al gore gets chased by the devil
Looks like a little metal dick on a stick.
LMFAO
Its an ashtray light. Its there to help guide the smokers in putting their butts smokes out.
looks like a pitted aluminum ***** to me.... :shock: :-#
oh i guess there is a hole in that second photo, didnt see until posting and looking a my post. :/
theres two of those small holes, easy to miss they so small, and its pretty dirty
Hot wire it and see where the light comes out. If the bulb is burned out, you can remove the rear section and change it.
that whole top should rotate off the light cover, on my Challenger it had a little blue cover, as said as above just ground the case to - and apply + to the wire should come on if the bulb isnt burned out!
