Timing specs - new cam installed
Mopar to ya
Rock Creek, Minnesota
I just put in an new Comp Cam XE268H in my 73 Dart Sport 318. Does a new cam run different timing specs or should I just set it to factory specs?
i would start from scratch. probably end up somewhere int he ball park of 17 initial and 35 total..
Thanks abodyjoe! That is a big help. Here is a video of the new sound!
[ame="http://www.youtube.com/watch?v=GK0c6FUfpc8"]http://www.youtube.com/watch?v=GK0c6FUfpc8[/ame]
Start around 16 initial and limit the mechanical. Isn't a "book" number that will help you.
Use a vacuum gauge, or just keep giving it more initial if it picks up rpm, resetting the idle speed to around 800 or so. You'll find a sweet spot. As long as the engine doesn't kick back when starting warm/hot, you have your initial setting. Limit mechanical to hit your total number and you're ready to go.
Good article joe posted too.
