What i have here are a pair of upper control arms that are used on the 1973-76 Mopar A Body cars such as Dart, Valiant, Duster, Demon. These control arms are required to be used on 1972 and earlier A body cars when doing a disc brake conversion to the larger 4 1/2 inch bolt pattern B or E body disc brakes or the 73-76 A body disc brakes.
I cleaned them up of all the grease and grime in the solvent tank, and then soaked them off in a solution of a product called Evaporust, to remove the surface rust from these control arms. You paint them the color, and texture paint of your choice. I will leave that up to you. A very nice pair of upper control arms. One of the best pairs that i have come across. Not rust pitted pieces of junk, from the rust bucket states here in the USA.
The control arm bushings were pretty much worn out and shot, so i removed them as a courtesy to my buyer. The ball joints are good and tight. You might wan't to use them as is. But i will leave that up to you, upon your inspection, and determination.
A very nice pair of UCA's. This set i found last week while making my wrecking yard rounds. This pair are now the last ones that i have in stock. These 35+ year old cars are not showing up in my area anymore, and these UCA's in this condition are getting hard to find.
$135.00 + what it costs for a box, and the FEDEX charges with signature delivery to your zip code.
e mail me at hemi71x@aol.com
Thank's a lot.
Jim V.
Thank's a lot.
Jim V.
