First test drive..
Scampin
Well been working on that 64 since I got it 3-4weeks ago. Took it for its first drive last night. Clutch needs replaced, feels like it is oil soaked. Trans popped out of second on decel. And I def. need to put some strut rod bushings in it. LOL. Other than that, cruised 70mph down thruway the 45mi to work no issues.
Did break the p/s wiper arm, I think maybe the spring internal to it broke. Can you replace the internal spring? Can you get wiper arms anywhere?
If you can't find one closer, I should be able to come up with a used bolt-on type wiper arm.
Thanks, Mark
Thanks Mark, I may have to take you up on that. Realized I haven't put any pics up. Had it buffed at work today, can't believe how nice it came out. Will take some pics tommorow of the outside...
Not a spec of rust..
Interior coming along:
Shampoed and re-dyed the shag carpet in the back:
Motor runs like a top, replaced fuel pump, all rubber hoses, cleaned gas tank, rebuilt carb, replaced distributor, plugs, wires, starter, new flex pipe to side pipes, found a 2-bl air cleaner, has 60psi of oil pressure...
New master cylinder, one brake line, cleaned brakes, "new" e70-14 poly's I had laying around, polished up the side-pipes, ready for some driving. Pre-buff.
Will take some "post buff" pics tommorow.
The side pipes came with the car. They are Thrush. It has about 6inches of the factory exhaust off the manifold, then flex pipe to the side-pipes.
I'd say its a 100% improvement. It's amazing what alittle elbow grease will do.
Just shampooed the carpet, let it dry, fluffed it up, then dyed it.
Wow nice solid little car and a few dollars and alot of elbow grease it's lookin real good.
Good work Scampin.
