sireland67
Installed a new set of 1.030 torsion bars when I rebuilt my front end.
I am having alot of trouble with ride height.
My stock torsion bars if you set them side to side with the hexagonal sides even, the other side is 30 Deg off, not in the same plane.
The aftermaket ones are completly even when you put them side by side, and in the same plane.
I am really sure I have a defective set of bars, I will call the manufacture in the morning.
Sorry to sound so complicated, but when you install the aftermarket torsion bars in the car you have two choices.
First choice the adjuster is the maxed out and the car is on the almost on the bump stop.
Second choice push the lower control arm down as much as
possible with no adjustment on the bolt you have at least 4" of height from the top of the tire to the fender.
This binds the upper control arm.
Does anybody have a set of aftermarket or original torsion bars laying around to compare.
Thanks
Thanks
