200R4 update
Transmission and Drivetrain Tech
02-26-2012, 08:41 PM
#76
Okay. Got the adapter plate cut down. Brought it in and ground the sharp edges off. Everything bolted up well. Dropped motor in to test fit everything. The tall Moroso valve covers hit the brake booster, so we loosened it to give a bit more room. It was a tight squeeze and we had to lower an inch, go back three inches, lower an inch. Finally got the mounts to line up and bolted the motor in. Got it up on the hoist and put a tranny jack under it an cranked it up. It hits the upper partion of the crossmember that curves around the tunnel. I took pics and will post them here, but unless you can stand there and see it, it's hard to tell and describe. My initial thought was, just cut out that section of metal. The bottom gets the under tranny crossmember bolted on anyway. However, the rear of the torsion bars go through this piece, and I don't want to lose all structural integrity. I think we can notch out the front side of the offending piece enough to clear the piece of transmission casing that hits. That will leave the bulk of the cross piece intact and we will still have the lower crossmember bolted to keep it all rigid. I think this will gain us 5 to 6 inches more in height, which we really need. The motor is sloped toward the rear far too much as it sits. Technically this is not part of the tunnel, so I guess Art can still say no tunnel mods are needed. I think we are going to modify the mounting of the original lower crossmember to move it back a couple inches. Then we can turn the mount around and gain another 3 inches. That should be very easy and I can still use my Mopar mount from Schumacher instead of buying a new GM mount. I need to bolt a plate to the 200R4 mount and drill holes a little further out for the Mopar mount because they don't line up. That's the easy stuff. I did get all new door and trunk rubber seals installed today and also the front cross drilled rotors. Productive day, but somewhat frustrating.
Adapter plate cut down and being cleaned up. It was a bitch to cut. Must be billet.
Adapter plate on motor and with tranny installed. The top two tranny mounting holes have no place to attach. I am going to drill through the plate and use nuts and bolts to bolt it to the adapter.
Motor and tranny going in and then in place.
Pic of the casing hitting the upper crossmember. I think we can notch out the front side, but we will have to cut so far back as to leave just a lip in front of the curve, and it will have to carry up to almost the top of the tunnel.
02-26-2012, 08:47 PM
#77
At least I got to do something fun today!
02-26-2012, 09:13 PM
#78
................There is always something to modify........looking good so far................kim.....
02-27-2012, 09:22 PM
#79
Senior Member
Quote:
Originally Posted by rednesss
The Wilcap is nice, but it's more than that. I am also swapping to a 2004R and ordered the Wilcap kit. The $550 is for a neutral balance kit, but they charge $100 extra to build flex plate for an external balance 360.
02-27-2012, 09:29 PM
#80
Senior Member
Oh, you might want to get a different tranny pan (an aftermarket one) with a drain plug in it. Trying to change the filter will result in tranny fluid all over the play due to the way the plan is designed (ask me how I know!).
But looking good so far! Gonna ask a dumb question but wouldn't a Big Hammer do the same job as cutting?
02-28-2012, 10:14 PM
#81
No. I still need the bulk of the upper to attach the lower we are making. If I beat the shit out of it, it will not only look terrible, but I won't have a good surface to attach and weld the homemade lower to. My next post will have pics of the cutaway part, the tranny up higher, and the beginning of a mocked up lower crossmember.
02-28-2012, 10:19 PM
#82
Senior Member
Quote:
Ah! Just thought I'd ask about the cross member and it be flattened.
02-28-2012, 10:24 PM
#83
Senior Member
Looks good, nice work !
The harder it is to cut the better its made. Be happy it was a bitch to cut
02-28-2012, 10:27 PM
#84
Can't Remember
Do you have subframe connectors?? If so, you can just triangulate from the subframe connectors to the torsion bar crossmember, thats how the fab guy did mine. The entire top of the torsion bar crossmember was cut out of my car and repllaced with a piece of flat stock, as well as the triangualtion.......
02-28-2012, 10:41 PM
#85
02-28-2012, 11:25 PM
#86
Senior Member
Gotta ask, how do you get the tranny back out (if need) if you weld in that back mount?
02-29-2012, 12:28 AM
#87
It won't be welded. It will be bolted. Welding would sure be easier, but we realized it may have to come out at some point in time. If I'm not snowed in tomorrow, I am going to get some heavier angle iron and make a working unit.
02-29-2012, 01:17 AM
#88
Can't Remember
Progress is a good thing.....
02-29-2012, 04:48 PM
#89
JACKSON, NJ
Great progress ,
02-29-2012, 06:36 PM
#90
Snowed in. Didn't have a way to get out of my driveway until after 3:00. Going to have to wait.
03-01-2012, 07:46 PM
#91
Not much time to spend lately. Today I got the head for my daughter's car from the machine shop and went to Discount Steel to buy the 2 1/2" angle iron we will use to make the lower crossmember and the round tube steel to slide inside the upper to give it something to pinch against instead of collapsing in on itself when the bolt is tightened. Tom had already started making the tranny lines. He is a genius at that stuff. It molds along the tranny close and even so there will be plenty of room for the headers. Saturday we will get a few hours put in on it and hopefully get everything test fit and we will be ready for full scale install.
03-01-2012, 07:52 PM
#92
Senior Member
Got any pictures of the upper cross member after reworking it?
03-01-2012, 08:06 PM
#93
Not clear ones yet. We cut it with the motor and tranny still in the car. I posted some pics a few posts ago, but they aren't clear, and we painted it black as well. Once everything is test fit and looking good and the lower crossmember is made, we will pull the motor and tranny out again. Then I will have clear picks to show what we did and why. With any real luck that will be Saturday, though we only have a few hours to work on it then.
03-01-2012, 08:13 PM
#94
Senior Member
Nice
03-03-2012, 08:34 PM
#95
The final cross member is done
03-03-2012, 08:45 PM
#96
Senior Member
Nice! Any plans to reproduce/market the crossmember? If so, how much?
03-03-2012, 08:59 PM
#97
I had no plans, but if the money is right .... I am a little worried about the exhaust. The original cross member had a slight curve that the exhaust went through, giving it a couple inches more room. I don't have that anymore. I did buy new Calvert Racing mono leaf back halves that will give me a 2" lift. That will allow me to crank up the torsion bars and give the whole car a higher stance. Maybe that will make exhaust clear just as well.
03-03-2012, 09:13 PM
#98
Senior Member
More then likely it won't give you that extra room because, you're just jacking up the suspension and the motor doesn't move/change or change its location at all which means, nothing will change.
What about some sort of notched (and reinforced) in the new cross member?
Or how about using oval exhaust tubing? http://www.spintechmufflers.com/oval...ng/cat_41.html
03-03-2012, 09:40 PM
#99
Funny you mentioned that. We were discussing ways of making oval exhaust tubing because it would keep the volume of exhaust flowing. I didn't know it was available to buy. I am planning on running the car on open headers about 10 blocks to The Wonderful Muffler Man. Ozzie has been doing my exhaust for years. His tubing could be used to make shotguns, it is so thick. I will have to ask him if he has oval tubing or if he can get it.
03-03-2012, 10:04 PM
#100
Senior Member
I think summit sells it, I just remember it. Being the "biggest" thing since sliced bread about 5-6 years ago (saw it in a Chevy mag). Might being a good way around said problem and not getting raped by TTi.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
