duster360
I have these items I would like to trade for a Big block 383 or 440 with automatic transmission or a set of 15 x 7 rallys with 4 1/2" bolt pattern. The motor/trans does not have to be a ready to drop in setup. I am looking for a complete buildable setup. The aluminum radiator ( it is new, never installed) will only be included depending on condition of what you have for trade. Must be within driving distance to trade. Trade value is around $600. If radiator needs included ( depends on what you have ) I have $240 invested in it alone.
Click the link for pictures:
http://s248.photobucket.com/albums/gg195/jaimie340/jaimie360/#!cpZZ1QQtppZZ24
Parts list:
B&M trans cooler - New cooler but no hose.
Lokar speedometer cable (fits GM trans) #SP-1501HT
Strut rod bushings #5-7109R
Shutoff switchs ( 2 of these)
Painless wiring fuel pump relay kit #50102
Dedenbear crossover delay box with post
Autometer pro shift light ( condition unknown-freebie)
3/4" NPT plug #AER-FBM3750
Water outlet restrictors #63440
Moroso starter switch #74120
Earls tube nut #ear-981808 ( 2 of these)
Jegs -08 AN to -06 AN female to male #100222
Jegs -06 AN sleeve #100392
Jegs -08 AN cap #100313 ( 2 of these )
Jegs -06 AN #100382 ( 2 in 1 pack )
Russell -10 AN straight to -8 AN flare reducer # 670660
Russell -10 Fuel cell bulkhead #670870
Russell -10 Dry sump union #670710
Russell Adapter fitting-flare to pipe- 90* -8 AN to 3/8" #660863
Russell Swivel coupler -10 #640023
Summit racing low pressure cutoff switch #SUM-G1438
Fuell cell rollover check valve
Bell Helmet ( size 7 1/2 ) with summit bag
Simpson fire jacket
'73+ Duster fenders
Miscellanious items also: '73+ Duster taillights and housings, headlight trim and buckets, grill marker light trim and lenses.
Parts list:
Simpson fire jacket
'73+ Duster fenders
