Ceritcard information
4spdragtop
Ontario Parts Unknown
I was wondering if anyone knew what some of the info means on a certicard? Dad has one on his 67 fish, here is a pic attached. The black label is the orig buyer info, and most of the "stamped" are codes relating to the build. On the 2nd row from the top it reads H6X ZZ1 T5 SG I22I. The codes I am unsure of are SG I22I
Thanks
4spdragtop
Wish I new. I actually Googled this earlier, as I have a Certicard for my Dart. Any hits I got seemed to suggest it was the same as a fender tag.
Sure Grip
December 21st (yes, they used I for 1)
hard to read it Steve H6X is the trim ZZ1 color, they should also be on fender tag. The T5?, SG is sure grip, I22I would be 12/21 1966 they use I instead of one for date.
Would you guys mind telling us where you found this?
The Certicard reads as follows...Top to bottom
Top Line= VIN information
second line reads.. trim code(H6X=Black Vinyl Buckets)-paint code(ZZ1=Gold Metallic)-transmission code(T5=Torqueflite Automatic) SG= Axle code( SG=Suregrip) Scheduled Production Date (I22I=Dec. 21, 1966)
Hope this helps. Incidentally, I got my information from Galen's Production Option Codes book 1966-68. Geof
Hey thanks everyone! Yeah I realized most of the codes were duplicates from the fendertag, but the T5 and I22I is where I was stumped...
Thanks again!!
