SLANT 6 Electronic Ignition Wiring Diagram Needed
Download 'em here
Conversion destructions
http://www.mymopar.com/downloads/elecignconv.pdf
Diagram for newer 4 pin box/ 2 terminal resistor
http://www.mymopar.com/downloads/Ignition_System_4pin.jpg
Diagram for older 5 terminal box/ 4 terminal resistor
http://www.mymopar.com/downloads/Ignition_System_5pin.jpg
It is IMPORTANT to know what kind of box you have. Not all 4 pin boxes have 4 pins. Some have a 5th pin, but not connected. Only way to tell is use an ohmeter and see if the 5th pin is connected
A 5 pin box MUST use a 4 terminal resistor
A 4 pin box CAN use EITHER a 4 or 2 terminal resistor. If you wire with a 4 terminal resistor, you can then use either box
Many of us don't run Mopar electronics, I use a Mopar breakerless distributor, triggering a GM HEI module. Simple, easy, they work
which came from this page
http://www.mymopar.com/index.php?pid=31
