A body front end body dollies
crackedback
Mopar body dolly wheel set. This is a pair of front brackets and (2) body wheels that bolt onto your unibody using the front bumper bracket bolts. You can then roll the body around in your shop or take it onto your trailer to go to the paint shop, etc.
Each set includes two front swivel caster body wheels. The front brackets are specific for A body cars. This is a front set only.
Here is a set on my 70 Swinger using a pair of 420ish pound capacity wheels. The car rolls around very nicely with little effort.
I have other wheel choices ranging from 400 pounds to 1200 pounds. I can make these for E and B body cars as well.
I've seen similar items that are all pretty and powder coated sell for 240+ and up.
My price for the std set up and 410 - 650 pound wheels is $149 + shipping from California. For the 1200 pound wheel option, add $45
Rears would be priced at $149 also.
5% discount on front/rear purchases.
If I make these slightly shorter than what's displayed, I believe I can ship in a USPS flat rate box so it would be about $15-20 anywhere in the US insured
This is good info for my future project. I'll have to save up and contact you. Thanks!
I can also build rear dollies that attach at the front spring perch location
Hey Cracked would you do a set front and back without the casters?
Yes I can do that. They will be set up for roughly a 4"x4.5" caster plate
No casters, for front and rear would be $200+ shipping
Hey guys, just wanted to add my two cents...
I purchased a set of these, as I needed to get my car mobile again. They are frigging solid! I trust my car on these way more than the heavy duty jack stands I had under the front end before. They are very nicely put together as well, almost too nice for thier intended use!
I will try to post up a picture of them is action tonight!
...I didn't know they made casters that heavy Rob! Thanks again man!!!:D
Yes, you can tow a car on a trailer with these. Got to use common sense. I wouldn't go cross country with them with a loaded down chassis, but a local haul using them is usually fine. i towed the car on my trailer with these pictured.
It's best to use these with a bare or close to bare shell. I do have the full interior still in my car, no engine/trans, and a trunk full of stuff.
Here are the rear one for Old School.
If someone can break these brackets moving a car around, I'd be surprised.
Do the rear ones bolt to the front spring attachment or to the bumper bracket area like the fronts?
For a Front/Rear set the total would be 290 delivered in the US via USPS.
That's really more than 5% off...
Hi
Very very nice, how much to ship a set to Toronto Ontario M3M 1H9
I think USPS would be the best
