Mopar mopar forum
 HOME  FORUMS   MEMBER PHOTO GALLERY  CHAT    REGISTER  FABO STORE
 MEMBER CLASSIFIEDS  VIN DECODER  VIDEO GALLERY
Our Network:  B BODY MOPAR FORUM  C BODY MOPAR FORUM  E BODY MOPAR FORUM  FMJ BODY MOPAR FORUM  CAR AUDIO TALK  PICKUP TRUCK FORUM  FOR JEEPS ONLY
Go Back   For A Bodies Only Mopar Forum > General Off Topic Forums > Racers Forum
11 to 1 on pump gas
Racers Forum
Thread Tools Search this Thread Display Modes
Old 05-23-2012, 06:01 PM   #1
bentman
Junior Member
bentman's Flag is: United States
11 to 1 on pump gas
can you run a ll to 1 on 93 octane if the time is set around 28 to 30*?
bentman is offline   Reply With Quote
Old 05-23-2012, 06:04 PM   #2
Badart
dillingerchassis.com
Badart's Avatar
Badart's Flag is: United States
We are going to need a little more info on the motor. Aluminum heads? Camshaft duration?
Badart is offline   Reply With Quote
Old 05-23-2012, 06:42 PM   #3
bentman
Junior Member
a iron RT head 585 lift 286duration 1.6 rockers
Old 05-23-2012, 06:44 PM   #4
OldmanRick
Layin Low Member
OldmanRick's Avatar
OldmanRick's Flag is: United States
Quote:
I agree, i'll assume it's a Abody but weight and gear would help also. Just trying to see how much load is on it.
OldmanRick is offline   Reply With Quote
Old 05-23-2012, 06:44 PM   #5
RustyRatRod
Senior Member
RustyRatRod's Avatar
RustyRatRod's Flag is: United States
Send a message via Yahoo to RustyRatRod
No.
RustyRatRod is online now   Reply With Quote
Old 05-23-2012, 07:31 PM   #6
OldmanRick
Layin Low Member
OldmanRick's Avatar
Quote:
Originally Posted by StrokerScamp View Post
No.
I just realized he's in Houston. With summertime heat, and iron heads, i'll agree completely.
Have to keep pulling back timing it's diminishing returns anyway.
Old 05-23-2012, 10:53 PM   #7
turbodart68
Senior Member
turbodart68's Avatar
turbodart68's Flag is: United States
Yes, if it has a loose converter and 3.91 or better gear. All day long.
turbodart68 is offline   Reply With Quote
Old 05-23-2012, 10:56 PM   #8
JoeDust451
Senior Member
In houston your right at sea level, even with 93 octane you'll be hard pressed running it on 11.1 with iron heads, detination city, you'll need to pull way too much timing & you won't be happy with the perf., shoot for around 9.8 or there abouts with good quench, modern heart shaped combustion chambered heads work wonders also.
JoeDust451 is offline   Reply With Quote
Old 05-23-2012, 10:58 PM   #9
JoeDust451
Senior Member
Quote:
Not on pump gas it won't
Old 05-23-2012, 10:59 PM   #10
inkjunkie
Can't Remember
inkjunkie's Avatar
inkjunkie's Flag is: United States
It will run....might not want to drive it though.....
inkjunkie is offline   Reply With Quote
Old 05-23-2012, 11:03 PM   #11
JoeDust451
Senior Member
Quote:
You ain't chitten!!
Old 05-23-2012, 11:05 PM   #12
inkjunkie
Can't Remember
inkjunkie's Avatar
Quote:
Originally Posted by JoeDust451 View Post
You ain't chitten!!
Golf ball in a trash can comes to mind....
Old 05-23-2012, 11:22 PM   #13
pishta
Senior Member
pishta's Avatar
pishta's Flag is: Hungary
reverse cooling. water to heads, then to block. Dont know how to do it in a SB, but the B/RB guys can do it with a shogun water manifold between the pump and the block.
pishta is offline   Reply With Quote
Old 05-24-2012, 01:27 AM   #14
1970Duster
Senior Member
1970Duster's Avatar
1970Duster's Flag is: United States
Quote:
Run a magnum cover on an la engine.
1970Duster is online now   Reply With Quote
Old 05-24-2012, 07:05 AM   #15
flyfish
C8H18+N2O = :-D
flyfish's Avatar
flyfish's Flag is: United States
11:1 on an iron head, relatively small cam, pump gas, near sea level....BAD idea.
flyfish is offline   Reply With Quote
Old 05-24-2012, 07:27 AM   #16
1968FormulaS340
Senior Member
1968FormulaS340's Avatar
1968FormulaS340's Flag is: United States
Sure it will run. I am at 11+ with iron heads. I can rumble through town if I keep the load off.
But it's really kind of pointless. You will have all this power that you can't use. Hell, a Geo Metro would probably beat you in a drag race, at least it won't be in chronic detonation when hammering on it, like you would be.
1968FormulaS340 is offline   Reply With Quote
Old 05-24-2012, 12:18 PM   #17
65Vsignet
Senior Member
65Vsignet's Avatar
65Vsignet's Flag is: United States
I run over 11.1 on pump gas! iron headed 360, at sea level in the heat no problem and i only get 91 octane california crap fuel.
65Vsignet is offline   Reply With Quote
Old 05-24-2012, 12:24 PM   #18
RustyRatRod
Senior Member
Almost made me spit coke all over my laptop. Best answer yet.
Old 05-24-2012, 12:41 PM   #19
Fst73_360
Senior Member
Fst73_360's Avatar
Fst73_360's Flag is: Mexico
if you know you the ABDC of the cam you can figure out what the Dynamic compression is and that will tell you if you can. most say 8.5-8.6 is 91 and 8.7-8.9 is 93,
Fst73_360 is offline   Reply With Quote
Old 05-24-2012, 12:48 PM   #20
RustyRatRod
Senior Member
Quote:
I'd like a link to that information. I am in the process now of trying to figure if I will be able to make my slant run on pump gas with the cam and compression I have. Everything I read says 8:1 DCR is max on pump gas with iron and 8:5 with aluminum. So far, I've seen nothing different.
On a side note, detonation isn't always heard. You guys build your engines however you want. But no way no how are you gonna run a blueprinted 11:1 motor with iron heads on pump gas without detonation. Anybody says different has been readin too many BS posts on forums from people that probably have never built an engine. Without quench, 9.2 is about it. With quench, probably 10.5 or so. You're gonna waste a lot of money if you listen to the wrong people.
Old 05-24-2012, 12:54 PM   #21
Fst73_360
Senior Member
Fst73_360's Avatar
just search it. It is every I have looked, I know I ran magnum heads, but i ran 8.6 DCR on 91 and DCG33 runs 8.7 on 89.
http://www.forabodiesonly.com/mopar/...d.php?t=155297
http://www.forabodiesonly.com/mopar/...d.php?t=180583
there are A LOT more, but here are some from this fourm.
Old 05-24-2012, 12:55 PM   #22
RustyRatRod
Senior Member
I hope you are right because my slant is coming up with some HIGH numbers for pump gas.
Old 05-24-2012, 12:58 PM   #23
Fst73_360
Senior Member
Fst73_360's Avatar
I am just going by what others are telling me and what engine builders like MRL and IMM have told me. You do not need to listen to me, my car is also in Ca at Sea Level. I had Kb107 at 0 deck which was actually 10.9 with 62-63cc magnum heads and a xe274.
Old 05-24-2012, 01:02 PM   #24
RustyRatRod
Senior Member
My slant is comin up with like 8.67 DCR and 10.482 SCR. I wasn't tryin to be contrary with you, just that I've read different stuff. All this DCR stuff is kinda new to me anyway, so any help is a plus.
Old 05-24-2012, 01:19 PM   #25
Fst73_360
Senior Member
Fst73_360's Avatar
Well altitude(sp)? plays a big part also. I will be running I think it is 8.8-8.9 DCR with magnum heads and 91 octane in Ca at sea level. Brian at IMM said he ran this same setup in INDIO Ca which is below sea level and ran fine. I will be mixing gas for break in though. After that i will carry some 110 in the trunk to mix just in case. But If I run 91 on 8.8-8.9 which most are saying needs 93 then I will be a happy kid!
Reply
Search this Thread:
Advanced Search
Display Modes
Similar Threads
Thread Thread Starter Forum Replies Last Post
Gas spills when gas pump shuts off buck351 Fuel and Air Systems 25 03-08-2012 06:16 PM
mopar gas pump Motopsycho Other Stuff For Sale 5 08-13-2011 03:26 PM
mopar gas pump Motopsycho Other Stuff For Sale 1 07-28-2011 08:05 PM
Old gas pump matthon Mopar General Discussions 20 04-04-2011 10:33 PM
I'm runnin on pump gas now! cudaspaz Fuel and Air Systems 12 04-19-2009 08:25 PM
Fabo Sponsors
Powered by: vBulletin Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Page generated in 0.27002 seconds with 38 queries
