Mopar mopar forum
 HOME  FORUMS   MEMBER PHOTO GALLERY  CHAT    REGISTER  FABO STORE
 MEMBER CLASSIFIEDS  VIN DECODER  VIDEO GALLERY
Our Network:  B BODY MOPAR FORUM  C BODY MOPAR FORUM  E BODY MOPAR FORUM  FMJ BODY MOPAR FORUM  CAR AUDIO TALK  PICKUP TRUCK FORUM  FOR JEEPS ONLY
Go Back   For A Bodies Only Mopar Forum > Automotive Technical Forums > Big Block A body Tech
Engine rattle
Thread Tools Search this Thread Display Modes
Old 05-23-2012, 10:37 PM   #1
WARLOCKII
Member
WARLOCKII's Avatar
WARLOCKII's Flag is: United States
Unhappy Engine rattle
Today we started our engine, 383 mild build. We ran the engine at 2000-2500 rpm, 10 degrees base timing, open headers, 50 psi oil pressure(with break-in additive) at 180 degrees for 30 minutes. Shut it down and checked for leaks. We installed a pair of mufflers and ran it for another 25 minutes. It has a rattle from the right side that we thought was lifters needing to pump up (sounds like valve train). We pulled the valve covers to check for loose parts and found that we could move the #8 intake rocker arm enough to get a .025 feeler gauge between the rocker tip and valve stem. We switched rocker shafts and push rods and had the same issue. We pulled the intake and there is no visable wear(can't feel anything with your fingernail), the lifters have a nice pattern in the center, the cam has a nice pattern on the lobes. We used a dial indicator and the #8 intake lobe has .003 less lift than the #6 intake lobe. All of the lifters on the drivers side were pumped up, 3 of the lifters on the pass. side were pumped up. Do you think we have an oiling problem, lifter problem or do we have a cam problem? Any suggestions would be great.
WARLOCKII is offline   Reply With Quote
Old 05-24-2012, 12:17 AM   #2
mopar7172
Banned
did u prime the engine before u started it?
mopar7172 is offline   Reply With Quote
Old 05-24-2012, 12:57 AM   #3
67Dart273
67Dart273's Avatar
67Dart273's Flag is: United States
Look up the oiling diagram in your shop manual. I don't see an oil gallery being a problem
Check the valve installed height compared to the others, otherwise check out the lifter itself.
I assume you checked the rockers and pushrods for length and wear
67Dart273 is online now   Reply With Quote
Old 05-24-2012, 08:33 AM   #4
WARLOCKII
Member
WARLOCKII's Avatar
We primed the engine and rotated the crank a few times while priming. The push rods are the same length and the rockers don't appeear damaged. Even with changing push rods and rockers the problem remains with the #8 intake. I'm going to check the valve installed height and install a new set of lifters.
Old 05-24-2012, 08:43 AM   #5
Purple Haze
Senior Member
Purple Haze's Avatar
Purple Haze's Flag is: United States
Soak the new lifters in oil before install.
Purple Haze is offline   Reply With Quote
Old 05-24-2012, 08:54 AM   #6
73AbodEE
440 Magnum powered
73AbodEE's Avatar
73AbodEE's Flag is: United States
im not trying to hijack your thread. im having the same exact problem with my 77 360. new cam and lifters, great oil pressure, lifters were manually pumped up before install, new rockers and shafts, pushrods all measured out exact. i have valve train rattle i cant get rid of. oddly enough, it is most noticable above #6 and # 8 so im watching this thread intently
73AbodEE is offline   Reply With Quote
Old 05-24-2012, 09:05 AM   #7
godfatherofchry
Senior Member
godfatherofchry's Avatar
godfatherofchry's Flag is: United States
try starting it with valve covers off then take a wooden handled hammer and put the wooden part on the rocker over the push rod and apply pressure down this sometimes pump the lifter up titer its worked for me in the past.sometimes it works sometimes it dont............Artie
godfatherofchry is offline   Reply With Quote
Old 05-24-2012, 10:58 AM   #8
RustyRatRod
Senior Member
RustyRatRod's Avatar
RustyRatRod's Flag is: United States
Send a message via Yahoo to RustyRatRod
I sure do love solid lifters.
RustyRatRod is online now   Reply With Quote
Old 05-24-2012, 12:11 PM   #9
Purple Haze
Senior Member
Quote:
I hear that.
Old 05-24-2012, 12:50 PM   #10
67Dart273
67Dart273's Avatar
Quote:
Originally Posted by Purple Haze View Post
I hear that.
I don't just love 'em, I actually RUN 'em.
The guys who remember what they are notice,
and those who don't know ask "why does your engine make so much noise?"
a "Because it's RUNNING!!"
b "because it's SUPPOSED TO"
c "because it's NOT a Pree Ass
d "it's a little low on oil, but hasn't got much worse the last couple of years, so I just leave it"
Old 05-24-2012, 06:32 PM   #11
BBBCUDA
Senior Member
BBBCUDA's Flag is: United States
Not saying it will, but I had 1 lifter on my 383 that rattled like crazy for quite a long time, and then decided all was well, and shut up. If you don't see any weird wear on the lobe or lifter, I would run it some more.
BBBCUDA is offline   Reply With Quote
Old 05-24-2012, 10:34 PM   #12
JoeDust451
Senior Member
I would check valve stem height 1st., then see if the lifter feels soft (spongy), you can feel that by pushing down on the rocker (lifter side), if its spongy, it just needs to pump up, i've had to replace them, even on a new builds, I don't use anything but comp magnum anti pump-ups on all my BBs anymore, had too many issues with the basic lifters rattling/callapseing, even with adj. rockers.
JoeDust451 is offline   Reply With Quote
Old 05-25-2012, 06:43 AM   #13
BBBCUDA
Senior Member
Quote:
Mine was one of the "inexpensive" Summit cams. I never liked hydraulics, and after this one, I really don't like them. I have a solid to go in this summer.
Old 05-25-2012, 07:51 AM   #14
73AbodEE
440 Magnum powered
73AbodEE's Avatar
Quote:
mine as well. i bought lifters from summit to go with it. less than 50 miles and i already have a completely collapsed lifter and a couple more that wont pump up. do not ever buy summit brand lifters.
Old 05-26-2012, 01:42 AM   #15
WARLOCKII
Member
WARLOCKII's Avatar
Smile
The shop that we bought our rebuild kit through ordered us new set of lifters to try. We pumped them up and installed them, changed the oil and filter and started it up again. The noise is GONE! Next time I'm buying a roller cam and lifters. Thanks for all of the help.
Reply
Search this Thread:
Advanced Search
Display Modes
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rattle rattle and rattle RaysGTS Mopar General Discussions 14 04-25-2012 05:06 PM
rattle can engine paint???? swinger340 Mopar General Discussions 17 08-20-2011 07:17 AM
upper engine rattle jqb122970 Small Block Tech 2 04-03-2011 02:33 PM
Rattle can undercoat clhyer Body / Interior / Trim 2 10-18-2009 12:23 PM
Strange Rattle Shane Small Block Tech 5 08-07-2008 09:28 AM
Fabo Sponsors
Powered by: vBulletin Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Page generated in 0.24881 seconds with 28 queries
